anyone have pics or have fitted 18 x 9 +30 with a 235/40 on the front of a 32 gtst?
i got mine on atm, adn its mm's from touching the uca, but i just would like to see how low people have gona with at the front
i am running coilovers so i can adjust, but cant drive car as engine pieces getting powdercoated
Nick
i'm looking at getting some meisters for my r33
looking at
19x8.5 or 9 at the front
19x9.5 or 10 at the back
what kind of offset is required? it wont be slammed i want to roll the lip on the guard
heres how it rides atm wit 18s 265s on the rear and 235s on the front no idea on offset of rims
okok thanks for that if those offsets are for sitting flush with the guards i mite go a bit lower in offset so its sticks out like 5mm
so something like 19x8.5 +25 and 19x9.5+30 and hopefulli i wont hit the guards when i put the dampers on the hardest setting
the issue is 19's arent great for fitment because u cant gain as much clearance by stretching tyres
from another thread in this section:
fitting a 9.5 +22 with a 225/45 tyre would actually be pretty easy, my main concern is being a 19" wheel, even though it will be the same amount of stretch, the angle will be sharper, like so:
the blue is a smaller wheel with a larger profile, and the red is a larger wheel with smaller profile but same size tread. the green is at sitting height, the yellow is on compression, the angle change in the 2 guards is due to dynamic camber, obviously in real life its the wheel/tyres angle that changes, but its easier to just show the guard changing angle.
as u can see the lesser angle of the sidewall on the tyre on the smaller wheel allows the guard to come down further, even though the offset, rims width and tread width are all the same. hence why its really hard to get agressive fitment on higher diametre wheels.
so its hard to really get the fitment right with them. with the specs i gave u, depending on the camber they will probably just stick out of the guard a few mm at the rear.
Hey everyone. First time posting here I believe. PM'd a few guys about things, but that's it.
Anyway, I have a set of TE37's I was planning on putting on my widebody Sileighty (S13.5), but since decided to go another route.
I currently have a '93 R33 GTS-T Type M coming across the Pacific and was wondering how well my wheels would fit.
In the front I have 17x9 +0 and in the rear, 17x9.5 +12.
I have no clue about Skyline offsets and to be honest, did not want to take the time to go through so many pages.
If someone could help me out, that would be super!
They will stick out the guards by heaps. About +25 to +40 is ok for a 33 GTSt.
Are you from the states?
u can make them fit, but u will need guard work, silvias usually have more clearance in the rear guards, the fronts are similar how ever.
heres a few pics, R33's have a bit more clearance than the R32's.
17x9.5 +13, 235/45 30-40mm flare (mock up with unfinished guard)
17x9 -1, 215/45, 30-40mm flare
17x9 +16, 225/45, rolled guards
Ive been reading through but just getting mixed answers
I have a 96 r33 gtst series 2. Currently has 17" work's not sure of the offset.
However i dont want to do any gaurd rolling or flaring (dont want to damage the paint) so im assuming i couldnt get anything over an 18"
What size, width and offset would you recomend for stock gaurds?
THANKS :D
width and offset play just as big if not bigger roles in clearance than diametre. u can make a 20" fit if u want, u just cant go as wide or have as low offset as a 17".
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
