just wondering what would be needed (if anything) to make a seto of 17x9 +22 (gtr offsets) fit a r34 gt-t.
depending on ride height & camber
but for my car needed no guard work to fit.
i had 215/45 front & 235/45 rear
Skyline model: R33 GTR
Wheel type: Rays Volk Racing RE30
Wheel diameter: 18"
Wheel width: 9.5"
Wheel offset: +15
Tyre size: 265/35 18
Suspension: TEIN coilovers (lowered 1" from standard)
Modifications to fit: None
Skyline model = R32 GTR
Wheel diameter = 20" all round
Wheel width =10" all round
Wheel offset =i cant remember
Tyre size =285-30-20
Modifications to fit = and the list goes on.......lip front guards,cut out small section of factory v-spec body kit,remove inner plastic guard liner and make own ones...thats the front.the rear fit well,just a bit of masaging in the inner wells.
the car runs ISC coil overs and is dumped 3.5" all round.
im looking to get a set of 18x10 +22 front and back i know the rear will fit cos of some crazy posts ive read and my guards are lipped and pumped 8mm
but the front im not to sure can any one help.
Skyline model = R33 GTST
Wheel diameter = 18
Wheel width = 9 front and 10 rear
Wheel offset = +24 front +20 rear
Tyre size = 235/45 front 245/40
Modifications to fit = adjustable camber arms :P and lip rear guards
Wheel diameter = 18
Pics?
Skyline model =R33 GTSt
Wheel diameter =18inch
Wheel width =(F) 9inch ® 10inch
Wheel offset =(F) 35 ® 37
Tyre size =(F) 225/35 ® 235/35
Modifications to fit = None
hey dave, how low is your car?u got adj rear camber arms?
coz atm i got 18x9.5 on the back and the rim hits my coilovers when going up a driveway, going to need a 6-7mm spacer at least to fix this. this might help you get the fitment right to prevent any scrubbing :)
Skyline model =R34 GTX
Wheel width =(F) 9inch (R ) 9.5inch
Wheel offset =(F) 19 (R ) 30
Tyre size =(F) 215/40 (R ) 235/40
*i might swap the front to the back as the rears sit in by 2mm and the front sits flush on the guards.
Stock height for now, have Tein Flex coilovers going in this week.
Though my engine and drive line are not in the car yet and this will lower the car alot, so ill have to wait and see.
no worries mate, post up some pics when you get them fitted :banana:
new fitment:
Wheel width =(F) 9.5inch (R ) 9inch
Wheel offset =(F) 25 (R ) 14
Tyre size =(F) 235/40 (R ) 235/40 (gonna try 245 next)
Modifications to fit = lipped rear guards
Skyline Model = R33 GTS-t Series II
Wheel diameter = 18
Wheel width = 8.5
Wheel offset = +35
Tyre size = 235/40/18
Modifications to fit = Rolled front, lipped rear (due to previous wheel fitments)
Skyline Model = R33 GTS-t Series I.5
Wheel diameter = 18
Wheel width = 10
Wheel offset = +22
Tyre size = 245/40/18
Modifications to fit = Rolled front, lipped and pumped rear by 5-8mm (front not done yet but that's all it needs) + i have next to no camber with a bit it would be nice.
I would say "just fit" lol Im sure you would encounter some scrubbing. When i had my 10.5 wide on the back over 1##km/ph the rear would be pressed down on the tyre causing it to wear pretty bad.
Looks awesome though!
Where did you get the rear guards worked on?
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
