That looks nuts Nisskid. Love it!
I have a 32 GTSt. Guards are rolled and pumped a bit.
I have Advan RS 18x9 +22 with 235/40/18 street tyres. They scrub a little but not too much.
For the track I use R33 GTR wheels (17x9 +30) with 235/45/17 semi's. No scrubbing at all when at the track.
f**king love it, very tough :P
if guard mods dont worry u, go the -4 and modify the guards to fit.
depends what tyre u wanna run tho, personally i think 8" is too thin for the stretch fitment as to stretch a tyre properly u need to go into the 100's like a 195 or 185, u can get away with 205's, but even then i think they are a bit thin if ur wanting to go fast. if its just a daily, or a street skidder, then the 205 will be fine.
Skyline model = HR31 Passage GT
Wheel diameter = 17"
Wheel width = 9" (front and rear)
Wheel offset = +15
Tyre size = 235/45R17
Modifications to fit = front guards rolled
could do with a ~15mm spacer on the rear.
Hey nisskid/SAU
im looking at a set of rims for my gts-t
Fronts are 17 x 8.5 +30
Rears are 17 x 9 +28,
i already have tires
235/45/17
i have height adjustable coils but its lot very low at the moment. also stock guards
how is it going to look? major issues?
ive read the whole thread but couldnt find a combo that matched.
Thanks guys?
Hey nisskid/SAU
235/45/17
Thanks guys?
17x9 +30 and 17x8 +30 both with 235/45's (closest ive got)
rear:
this is a close up of a 17x9 +30 on the front, will be fairly similar to a 17x8.5 +30
your guards may need a roll depending on alignment and suspension. mine was very borderline at the rear with stock arms (fair bit of camber). front i had no issues with, but that was because my suspension never compressed enough to really push the tyres into the guard. so i would try them on, and see if u can get away with them, if not get ur guards rolled and ull have plenty of clearance.
can sumbody please confirm that 19x10.5 +9 Volk GTC face 1's will fit on a r33 GTR with standard brembo brakes.
Also what size tyres will i need
Edited by UWISSH!
  • 4 weeks later...
Skyline Model = r32 2 door
Wheel diameter = 17
Wheel width = 9
Wheel offset = +22
Tyre size = 235 front 255 rear
Modifications to fit = role heck out of guards. mainly because front of car is so low and rear tyres are too wide
hey guys been reading through this
need help
from what i gather (have a r34 gtt 2 door)
if im after 18s and want to avoid modifications, safer to go with 18 x 8s ? rather than say 18 x 8.5 or 18 x 9.5
will 18 x 8s also allow me a lower offset? from what i gather this would be the case? and this would mean a deeper dish effect? would this look good?
correct me if im wrong
also atm my car rides high at stock height, if i get rims i'd lower it a bit... does this help or detract?
cheers!
dish comes from distance between disk, and the outside of the barrel, this same distance determines the wheels clearance from the gaurd. if u just want clearance, go 6" wide with +40 offset. my point being u need to provide us with a bit more details, do u want the wheels to sit up near the guard? do u want wide tyres? etc etc
after speaking to a couple ppl, i've changed my mind, i am willing to roll the guards now
if i did 18 x 8.5 front and 18 x 9.5 back
would this fit on my car and with wat sort of offset, i was looking at +15 or +22 ?
regards to tyres i don't have too much knowledge on tyres atm but from what i've read here for the tyres im after im thinking 255/35/18 for front and for back 265/35/18
would this be a nice look withou being too bumpy a ride?
Edited by vudoo
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
