yeh front will be close to the UCA, bloody close, generally i say 235/45 with a +30 offset is the furthest in id go, 225/45 will protrude 5mm less in, and about 4mm lower, but u have 8mm more offset pulling the tyre in further. so it will definitely be close, and probably come down to the tyre model and individual car as to whether it actually scrubs or not, but nothing a spacer a few mm thick cant fix.
my bet is that it will clear, but no guarantees on that one.
do you know what the difference in diameter of a 235/45/17 tyre and a 235/40/18? I'm guessing only a few mm.
I had 17x9 +38 with 235/45/17's and they were fine on my 32.
Cheers for your help.
I'll find out in a couple of weeks when they arrive if I need to run a spacer or not, but I couldn't say no to the rims. Silver GT-C's on a grey 32.....mmmmmm tasty ;)
mm, yeh it comes down to each car and tyre design it seems, when i ran 235/45's with he +30 on mine, i could feel maybe a 3mm gap between the tyre and UCA.
Yeah i've had some bridgy 235's and they were way skinnier than a dunlop 235 haha. dunlop sat square and bridgy looked stretched!
yeh when i used to drift on 2nd handies id go through so many tyres, and it was crazy to see the difference in them every time id put a new one on, all different brands had different shapes and clearances mounted up.
Hey nisskid, going crazy trying to work out what to do with ordering new wheels, especially seeing as tho i cant trial fit...
Currently looking at a set that i can get in the following -
路 18 x 8 only comes in offset +35 and +45
路 18 x 9 comes in offset +20 and +36
路 18 x 10 comes in offset +15 and +35
would ideally like a mildly aggressive fit, but dont want to have to flare. dont mind a roll and removing the plastic guards tho.
looking at 18x9 +20 front and 18x10 +35 rears or just the 9"+20 all round on an R34 GTT lowered on nismo coilovers, no camber adjustment as yet
any advice?
thanks mate
any advice?
thanks mate
thats a hard one, as 18x9 +20 would sit pretty nice and aggressive, but 18x10 +35 is a bit soft, and wont really suit the agressiveness of the front. u could go 18x9 +20 all round, but if u want to keep the staggered width, id be going the 18x10 +35 and correcting the camber to around -0.5, this will pull the top out, and give u more grip. from there id probably go extended wheel studs and some hubcentric slip on spacers to get the fitment perfect.
the 10" +15 can be made to fit without a flare, but ull need camber and stretch, and by the sounds of things its more aggressive than what ur after.
thanks heaps mate, pretty much what i was thinking.
its my daily after all so i'd prefer not to go too crazy, but i just remember not being entirely satisfied with my last wheels on my old 33 (cr kai 18x8.5 +32 / 18x9.5 +38). fit really well but could have looked a lot better, which is why im kinda shy of going the 18x9 +36 and 18x10 +35 in these wheels.
hey fellas how would these fit on an R33 gtst
18x9 +15 (front)
18x9.5 +15 (rear)
btw my rear guards have been rolled flat so shouldnt be too much issue there
also i was thinking tire wise
215/35/18's for front
235/35/18's for the rear
18x9 +15 (front)
18x9.5 +15 (rear)
front might sit out slighty ive got 18x9 +30 on front with 25mm spacers and it sticks out about 20mm atm but putting wider front guards.. back should be fine
nisskid will be able to tell you better though!
that set up should be fine although im not sure about those tyre sizes wouldnt that be not enough sidewall to stretch? well i guess it would jsut be harder to stretch
just a quickie
how bad would it be too occasionally run on the track
225/45R17 front
265/35R18 rear
cause i got spare pair of 18s with 265/35 and dont want to waste it
and i thought 225/45R17 would be good comprimise for grip/drift front tyre, i would go a 215 but i think the difference to 265 is too much
cheers
18x9 +15 (front)
18x9.5 +15 (rear)
will be quite aggressive, id go a 225/40 on the rear. depends how much camber u have, as it will be tight, but depending on the camber u will get away with it.
running -2 degs on the rear and -0.5 on the front, so the fronts would be ok with that width and aggressive offset?
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
