Hey Braddd, this is my first post and I don't want to come in too hard straight off the cuff, so forgive me if this sounds too authoritative, but you know thats not legal right?
225/40R18's shouldn't be mounted on anything bigger than a 9" wheel.
215/40R18's shouldn't be mounted on anything bigger than a 8.5" wheel.
with that in mind have you considered;
rear: 255/35R18
front: 225/40R18 or even a 235/35R18 (a bit hard to find)
:):laugh: :laugh: :laugh: :laugh:
dear god, someone illegally modifying their skyline, we must alert the prime minister!!
is this manual what police will defect you via?
i got done on the weekend for a 235/40 on a 18x10 so now im thinking ill just stick the right size what is recommened for 10" in your book pls?
Yes... it is.
your 235/40R18 is 645mmOD
10" options
255/40R18 is 661mmOD
255/35R18 is 636mmOD
265/35R18 is 643mmOD
its all about the stretch! haha
are you sure 225/40 is legal for 9" rim? i would have thought youd be pushing it..
bradd u wont need to flare rear just roll guards and camber should look tough as! ive got 18x10 +20 and i just rolled but havent dumped it yet may need more guard modification when i drop another inch.
also nisskid what are the chances of fitting a 255 or 265 under r33 guards lots of camber im guessing?
i guess my question is, why do u want a 255/265 if ur willing to run a lot of camber? lots of potential contact path, but with a lot of camber ull end up with less contact path than a 225 with less camber.
u can get 255/265's under 33 guards easy with the right offset.
cos they almost made me get my car towed home :) so id rather go with a bigger tyre / camber and keep the po po off my back.
slightly off topic u know anything about hsd coilovers? how u rate em?
best u can do is play around with 2nd hand scraps of different sizes until u find out how big u can go, then just buy a tyre in that size.
as far as HSD's, when ur talking bottom of the line suspension they are good in comparison to other stuff of it's class, seems the BC stuff has been all the rave recently tho, and a good mate of mine reckons they are decent based off some research, so id be inclined to believe him. although tbh, i never really recommend anything that cheap for cars like ours, it's just all too low quality imo
yeh fair enough i figured they werent going to be high class but all the jap stuff is very pricey atm but i think i might just stick with teins do it right once.
thanks mate advice is spot on as always :)
nothing wrong with providing a bit of information mate... how it's used is up to the individual.
true, but u'll find generally people going outside the boundaries of whats recommended understand that. tyres very rarely pop off the bead for no reason, and it's no different with stretched tyres, ull find only the ridiculously stretched tyres ever come off simply under additional load.
yeah nisskid I know you regularly run stretched tyres and so do many people, and you probably have not had an issue.
but to me going against the actual manufacturer's recommendation, as well as ADRs so it looks drift hectic is pretty silly.
just buy wheels and tyres that fit the car properly and safely.
any time you are relying on a inward stretched sidewall and camber to tuck the wheel inside the guard it is getting pretty silly.
Wouldn't you get done for having a too wide rim anyway? like the 2in wider than standard rule.
I assume it's a gtst? so 16x7 standard.
Here's the thing,
There is another manual used called the Universal Tyre Fitment Guide which lists all OE fitments of wheels/tyres/offsets for australian delivered cars which is also used by authorities on matters such as overall tyre diameter increase & track increase etc (mainly for 4x4's). Because it only references Aus delivered vehicles, only select Skyline models are shown such as R31's and some GTR models.
Without a reference as to what an imported vehicle came with as standard it is near impossible for police to prosecute, unless however the tyre placard on the vehicle clearly states a rim width (most don't). So with this in mind, assuming you are within the recommended outer tyre diameter as per your local authority and the tyre is mounted on the rim as per the Tyre & Rim standards manual you 'should' be fine.
Every state authority is different though, it's up to the individual to do his/her due diligence.
police in tassie are totally oblivious to this shit, get defected for totally bald tires and thats about it, maybe if you zorst is too loud...
:D:D:):laugh::laugh:
LAAAAAAAAAAAWWWWWWWWLLL
Edited by Braddd
each to their own, there are reasons why manufacturers only recommend around 3 sizes for 1 wheel size, mainly because there is no reason to do otherwise. 3 sizes is a big enough window, and there is absolutely no reason for tyre manufacturers to widen the window, as low as the risk may be.
and ADR's are simply based off manufacturers recommendation, they carry zero merit on their own.
and for the record, everyone does things to their cars every day to make them look and sound better that make their cars illegal, wheel fitment is no different, it's just some dont get it, but that's the beauty of styling, everyone has different taste. some times u just have to accept that you dont like the styling, but many others do, just like you may like the styling of ur car, but many others dont.
also for the record, although this is kind of off-topic in this situation, stretch can be used to firm up the sidewall of tyres that dont have the reinforcement that high end performance tyres do. a good example is im currently supplied neuton tyres from my sponsor to drift on, now they are a cheap tyre, and yes ideally i'd like to run high end tyres, but when ur chewing through a pair every few sessions then it's just not ecconomically viable at my level, so what i will be doing is getting rid of my 17x9's on the rear in chase of some 17x10's, but keep the same 235/45 tyre, this will stretch the tyre more and give me more feel, yes the unsprung weight will go up, but with the added feel, and minimised deformation of the soft sidewalls, it's worth it.
just to correct here, standard gts-t is 16x6.5 (+40 if relevant), so even less lee-way.
also even if he doesnt get done for too wide, they will do him for protruding tyre, if a officer can look down the guard from directly above, and see tyre tread, then apparently it's illegal, or at least in police's eyes. the biggest issue with this is police struggle to grasp the difference between tread, sidewall, and rim.
That's not 100% correct.
Whilst Australian Standards are developed in conjunction with manufacturers (along with engineers, industry professionals and international associations) they are not based on manufacturers recommendations solely and at times a manufacturers recommendation is at-odds with the Association standard. In such cases the Association Standard overides any manufacturers recommendation.
An example:
Mickey Thompson MTZ 285/75R16 - According to the manufacturer it may be mounted on a 7" rim
Australian Standard says minimum for a 285/75R16 is 7.5".
In this case the Australian standard overides the manufacturers recommendation.
Apologies for getting all technical.... and sorry for using a 4x4 tyre as an example, it's just something that came up the other day and was fresh in my mind.
Edited by thewheeldeal.com.au
fair enough, so engineers in Aus have tested every single tyre size on every single wheel combination to determine what's safe and what's not?
Safe or not mate, it's the rules... I didn't write them, if you have an issue with them then take it up with the Tyre & Rim Association of Australia.
no you just said that they weren't based off manufacturers, which made me think it was based off their own tests, that would mean they would have to test it all themselves and engineer every single possible combination. if not, then afaik my statement still stands that they carry no merit of their own, they are just guidelines based of standards given by other sources.
i think people should look at what the evidence is before making their decisions, if people really want to stretch, then they can look at the others that drive/drift/race on stretched tyres and they can make their decision based off that, i have, and i am yet to find a case of a tyre popping off the bead with mild stretch besides crashing or hitting something, therefore i made the educated decision that stretching was fine. if people arent willing to take the "risk" themselves then good for them, but expect to be greeted with opposition if you suggest it's unsafe without any real evidence.
FFS, wheeldeal.com/whateverthef**k, its the job of the police to enforce the law, thank you for sharing the laws however i think you may find that the people on this forum put certain rim and tyre sizes on their cars because they WANT to, in order to achieve a certain look. and in doing so are prepared to deal with the police attention and such. so i dont think they care. myself included.
also bitchin like this makes the site seem like boostcruising.com and bloody nobody wants to end up like that joker of a forum...
Edited by Braddd
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
