Hi guys,
can anyone tell me the offset that would fit flush with the 33 guards
front 18x8.5
rear 18x9.5
been reading this topic but just cant find it, always slightly in or out
+30
Hi, I need some advice on fitment.
Would it take a lot of work to fit something like F: 18x9.5 + 30 R:18x10 +30 to a 33 GTST?
Have Tein superstreets fitted.
Thanks for any help/advice you can give
will require guards rolled and slightly flared if the car is low. front liners will have to be removed.
the fronts will sit out 5mm less than this: (bearing in mind that i pulled the guards to exactly where i wanted them)
the rears will sit out 1mm more than this: (bearing in mind that i pulled the guards to exactly where i wanted them)
yes should be fairly ok, front might be slightly mexican but a good roll should fix that. back will be fairly easy with a roll only needed and maybe a 235 or 245 tyre depending how low your car is.
all gonna come down to car height on this one... i run fairly low, (320mm rear and 325) front so flaring was req'd with 235's and this is pretty much exactly the same
im sorry i dont follow 320mm what? off the ground?
30three- dont forget camber..
i've gone the less width way and more offset for the set i'm getting for my 33
they are 17x8 +5 on front and 17x9 +11 on rears.
currently they have 205/45r17s on front and 225/45r17 on rears. will see how they sit on stock guards with slightly lowered suspension but i'm thinking 215's atleast for front.
will update with picture i nthe next week ro so.
should be fine, maybe a little conservative if your going for flush look i think a few people are running 10" +22 but im not up with r34 fitment.
Think he means centre of wheel to guard. forgive my n00bness i dont know what that means still haha..
Hi guys,
I'm looking at some Tri spoke rims for my r33 gts-t. They're being sold without tyres. Basically, these are the specs:
17x9 20+ fronts
17x9 35+ rears
I know little about offset etc, but will these wheels suit my 33? Please bear in mind that the car is lowered slightly, but I do with to go lower down the track with coilovers etc.
well u'd want the higher offset rims on the fronts if anything and +35 9" wheels might scrubs on the inside if your low so test fit them first. 17x9 +20 should fit on the rears fine if you run a thin 235 or a 225 tyre.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
