a little camber on the fronts couldn't hurt...
now roll those guards and slam that bitch!
im running -2.8 atm, can't get anymore without getting some aftermarket LCA.
ahaha don't think i be slaming her just yet.
also i don't mind if they hang out ahahaha
sorry i didn't introduce myself at the dyno day today billy... i only worked out who you were when you drove off today lol
your car looks mint with those sizes, and the black worked sooooooo well!
Hi all,
I have 33 GTR, it's lowered with Cusco Zero2 coilovers.
I was wondering what would I need to do to my R if I want to put 18x10.5 +/-0 (there is a pair of SSR Sp1 in this size for sale on ns.com, that I'm tempted to buy this pair and order new pair)?
Or I may be better off buying 18x10 +18 and leave the ride height as is (345mm guard to centre front and 335mm rears)?
Thank you in advance.
Cheers
Grant
Seen heaps of people with 10.5 +12, so 10.5 +/-0 would need fair bit of work also 245/40/18 is alright for it to stretch over 10.5"?
I'm thinking roll the guards, lower it a bit more, anything else I may need to know?
I have 19x9.5" +12 (selling it now) rays fortessr, it fitted inside guards so would need to look at heaps of pics with 10.5 +12 to give me some ideas.
Cheers
Grant
245 will fit but it'll be a *bit* of stretch depends what your comfortable with i dont know much about stretch on gtr's since i gotta gtst... but yeh to make it fit, roll, stretch, low but possibly camber OR flare depends how it sits.. post a pic if u got one of 10.5 +0
Hmm...
Might have to make an time for inspection of the rims I mentioned earlier and see what I'm getting myself into.
Alex, thanks for your help.
Cheers
Grant
haha all good dude, I thought it was you...
Cheers
Grant
Im also really tempted to get those wheels.... I have an offer for my wheels but its a hard choice to make.
I'd need some crazy stretch 225/45 and some more guard work though.....
8mm slip on is huge.. get 10mm bolt on hubcentrics if u can
run 10mm hubcentric spacers ! are they concave front and rear ? post pics
so i ended up with 10mm bolt on hub centric spacers at the front :down:
only pic i have so far showing the fitment... comments welcome.
Skyline model = R33gts
Wheel diameter = 18"
Wheel width = 9.5"
Wheel offset = +12
Tyre size = front-235/40/18, rear-245/40/18
Modifications to fit = rolled lip front and rear, front plastic removed, rear camber arms (dont really have to have them, just helps)
    • My son saw this Porsche 904 in Yodoyabashi in Osaka, not sure if it's the plastic or fibreglass version 767605763.559358.mp4
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
