Do you know the offset of your current rims? If they are the ones in your sig, I'd say they will be about the same as the ones you want to buy. Do you have coilovers?
I dunno wat they r, ill have to take wheel off tomorrow n check.. No coilovers only damper adjustable shocks.
i cant see an issue as the offset is quite high so it should sit well within your guard i dont have a 32 though.. whats the current wheel offset u have?
you an always go a smaller tyre OR roll your guards it wont effect ur paint/body work and will give you more clearance if u want bigger tyres.
I have to check in the morning what my current offset is.. Nah its not that im worried about having 2 roll guards, id do that with ease.. im worried the wheels r gonna sit too far into the guard n look mega gay. lol
Found some secondhand 18" driftek for sale
Front: 18x8.5 +35 multi stud 4 or 5 hole 114.3 PCD  225/40/18
Rear: 18x9.5 +18 multi stud 4 or 5 hole 114.3 PCD 245/40/18
I know the fronts should be fine for a r33 gtst but what about the rears? An offset like that is more suited for a gtr I thought. What would be required for them to fit a r33 gtst?
fronts will sit in a long way compared to the rears... my guess is they came off a car with bolt on spacers for the fronts
to fit the rears you will need to flare the guards (you could also just lip them and use heaps of camber and stretch a 225/40
nah rear will fit easy with a roll joey..
front will look a bit crap should be ok for brakes cos of hte rim design but it wouldnt be my first choice but u are limited drifteks only have 2 options
sexual 32 i'd stay away from anything over +25 personally that way you will get pretty close to flush fitment and if you go 18s you can go lower fora nicer stance which it sounds like thats your aim..
  • 3 weeks later...
those offsets are pretty conservative. My main concern is staying away from spacers and stretching/camber although I am fine with rolling
sorry i missed this.
lower offset means stick out more.
so conservative as your mention +30 or higher will be very sunken causing you to need spacers.
you will find you can easily fit 9.5" + 18 with a roll
been searching this whole thread, so many opinions.
r33 gtst.
looking for 18 or 19" wheel. been looking at volks.
whats a good offset that wont scrub? i dont want crazy look with a wheel halfway poking out. nice and flush-ish. but has to look faat.
reccomendations?
a bit contradicting u want fat but no poke..
im gonna guess that you'll be prepared to roll you guards.
if so i'd suggest 18x9 +20 front and 18x10 + 18 - +25 depending how much camber or what tyres your gonna run etc.
others might have different opinion but specs similar to that will give you a nice look, but depends on ur ride hieght to
hey alex, on that topic, i just ordered my new rims for my 33, 18x9 + 20 and 18x10 +18 (rear) im gonna run a 235x40x18 tire on the rear, how much camber do you reckon ill need to get some hellaflushness happening? guards are already rolled flat...
Edited by Braddd
  • 1 month later...
Skyline model = R32 GT-R
Wheel diameter = 18"
Wheel width = 10"
Wheel offset = +13
Tyre size = 245/40
Modifications to fit = Stiff coilovers, bit of camber, slight stretch on the tyre.
Sits tuff as nails :D
Skyline model = R34 Gtt sedan
Wheel width = 9.5"
Wheel offset = +15 all round
Tyre size = 235/40
Modifications to fit = Bilstein shocks (soon to be coilovers) and slight stretch on the tyre.
Got some rotas, Craziest offset I've ever fitted.
Wheel width = 9.5"
Wheel offset = +12
Tyre size = 265 35 R18
Modifications to fit = roll lip on guards, bit of camber
Other wheels are nismo 400R wheels,
Wheel width = 10"
Wheel offset = +15
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
