Okay thanks. So the 255/40 is slightly smaller than the 235/45. Obviously this would have an effect on the speedo reading. would this still be a good option for the rear, or am i better off sticking to 235/45 all round? Intended use is track days, hillclimbs etc, with occasional street driving (ie. to and from the track)
Cheers.
hey guys scratchin my head on whether to grab a set of wheels. i want just a clean fitment basically flush with the stock guards with just a roll and lowered.
fronts are 8.5 +30 i know these will sit nice and flush
rears are 9.5 +40
now are these going to sit in to far that they will look complete odd and different when compared to the front or are we talking 5mm will make a match. or is 9.5 +30 what i really want to match the front? because i could live with 5mm but probably not 10.
basically there a good buy and been searching for a while
cheers coops
Cheers.
Go 225/40R18 and 255/35R18 for the same rolling diameter as stock :blink:
well going by that then im better off going 9 +22 all round so they sit +14 more fronts and +12 on the backs making it sit flush
being Te37s as well theyll have the concave look and not look so crap
agree?
9 +22 all round is a much better option as long as you have clearance to your struts :)
Skyline model = r34 gtt
Wheel diameter = 19inches
Wheel width = 8 front 9 rear
Wheel offset = +23 front +9 rear
Tyre size =215 front and 225 rear
Modifications to fit = everything lol, flare, roll, pump, remove inner plastics.
next set of rims will be even more ridiculous probs go bolt on flares
Hey Guys,,, :D
Sorry.. Bit of a noob when it comes to tyres etc
I'm chasing some tyres for an 18x10.5 rim (Rear)
Would someone be able to suggest what size tyre i should be chasing?
For an R34Gtt Running Full Cusco Coilovers and arms etc
Guards will be rolled...
Hey Guys,,, :domokun:
I just ordered 265/35R18s for 10.5 +30s on the rear of mine :(
235/40R18 is a good option for you as well.
Skyline model = R32 GTS-T
Wheel diameter = 17" enkei RPF1
Wheel width = 8.5" front and rear
Wheel offset = +30 front and rear
Tyre size =215/50/17 front and 225/45/17 rear
Modifications to fit = none. and the fronts rubbed the guards quite badly. didnt want to have to modify guards as i've seen other r32s with modified guards and they look terrible, unless converted to genuine GTR guards. so i got rid of these wheels lol
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
