Sydneykid, You have posted that r33gtr wheels are 17x9. I take it the blue stagea on the bottom of your pages is yours. Are they r33gtr wheels on it?, because my s2 has wheels that look the same but are 16x7. Cheers. Jason.
Skyline model = R34 GTT
Wheel type : stock r34 gt-r wheels
Wheel diameter = 18"
Wheel width = 9"
Wheel offset = +30
Tyre size = 245/40 Front & 265/35 Rear
Modifications to fit = None. But if i lower it more then i might have to lip the guards
Just love the look & design of the rims. And they are pretty light forged rims. Heard they are BBS manufactured.
et +30
Skyline model = Kakimoto Widebody R33 GTS25T
Wheel diameter = 17 Inch
Wheel width = 10.5" front/ 13" rear
Wheel offset = (Don't Know)
Tyre size = 255/40/ZR17 F, 335/35/ZR17 R Pirelli P-Zero's
Modifications to fit = Front and rear castor adjustment by Kakimoto, HICAS disabled to prevent rear wheel steering. Both front and rear wheels sit about 1/2 an inch inside the guard.
how do you measure the width of wheels. the guy i got them off said they were 9.5' wide...i measured them and the are like 10.2'. im a bit confused. thanks for the help
i have 2 on the rear of my 32gtr and the fill out the guards nicely, the guards are only a few mm wider than these wheels. looks nice!
Edited by Turbz_13
I quickly checked though the thread and I haven't seen the obvious R33GTR rims (17 X 9 X 30) on an R33GTST. Do they fit with 255/40/17 tyres without guard lip rolling?
:D cheers :(
10 inch rims on an R32?? Easy bro... just check out mine ;). And even better, it's on a GTS-T R32 not an R lol
Skyline model = 1989 R32 GTS-T
Wheel diameter = 17 inch Front / 18 inch Rear
Wheel width = 10 inch wide Front / 10.5 inch wide Rear
Wheel offset = hehehe
Tyre size = 225/45/17 , 235/40/18
Modifications to fit = Rolled / pulled the living hell outta the front & back.
I can bet you a million bucks that 215's can fit on 10 inch wide rims, u just gotta know how to get em on.
Link to pics: http://www.pbase.com/suomyairsoft/new_rims
10inch will need 265's, 255 may fit with some major stretch factor.
I'd be very interested to see some pics of anyone's R32 with 10 inch rims
Regards
Andrew
asked the wheel shop about some wheels that are 19x8.5 fr +38 and 19x9.5 rear +45 for a r33 gts-t and he said will fit fine just need to run a spacer for the front so it dosent hit the caliper.
Ill be going 245 on the front and 275 on the rear.......
i previously had 275 on the rear (with a smaller rim) and with my lipped guards cleared.
what you guys think they will fit?
  • 4 weeks later...
Skyline model = SII R33
Wheel width = 8.5" Front 9.5" Rear
Wheel offset = 38
Tyre size = 235/40 Front 265/35 Rear
Modifications to fit = None, but the rears come DAMN close to calipers =D
Skyline model = 93 r32 gtr
wheel brand AME Circlar gta (cant get em in aus)
Wheel diameter = 17
Wheel width = 9
Wheel offset = unknown
Tyre size = 255 40 17
Modifications to fit = nil
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
