GOT SOME NEW RIMS NOW
18x9.5 +15 te37s
rears will fit sweet (i think perfectly flush)
fronts will stick out about an inch i think so gonna dial in some camber and some stretch and see where we go from there hahaha
Roll the guards perfectly flat with some Cusco camber arms maxed in and they'll fit with ease :)
http://i33.photobucket.com/albums/d85/anml...rx/S6300027.jpg
WHEELS IN THE PICTURE ARE 17=8+5 FRONTS WITH A 215 40 REARS ARE 17=9+10 WITH A 215 40 work vs-mx
OLD WHEELS ON MY 32 KINDA MISS EM ....
ANYWAYS GOT A BIT OF A WHEELS PROBLEM FELLAS RUNNING 16=8-4 rears sit fine atm ...but the fronts arent clearing the brakes .so i put a 5mm slip on on the hub but thene the wheel sits off the hub! (danger!!!) cant put a bolt on on because it sits out a bit as is ...
the wheels have a steel insert was thiknig bout pressing them out and running a SHANKED STYLE WHEEL NUT (HOLDEN ,TOYOTA STYLE)
THAT WAY I CAN RUN THE SPACER TO CLEAR THE BRAKES .AND JUST HAVE A LITTLE MORE PEACE OF MIND AND SUPPORT ON THE WHEELS BTW THE SPACERS ARE 8MM SLIP ON ! ANY SUGGESTIONS WOULD BE APPRECIATED CHEERS FELLAS ..PICS WANTS THERE ALL ON
Edited by talky
pic dont work.
wouldnt bolt on spacers solve your issue as you will have new studs?
asi stted in my previous post ..cannot use bolt on wheel spacers as that will make them 8-20 and will sit mexcian as .so im trying to get around it ...but dont really wanna remove the inserts! but might have to
without looking i'm gonna guess this will be a pic of superlights on a 31
speak to jezzaGTR as he has the same setup (if i'm correct)
hey mate nah its a 32 4 door thought id try something diffrent with the 16s and yer there superlights lol.....so im just trying to get em to work properly arghhh
5mm slip on should make it impossible to put the wheel on..
roll fronts + camber?
or
flare?
easiest option sounds like what u suggested..
mmm its already got a lil flare and i dont wanna the front look stupid compared to the back man mmmm ill see wot happens wene i remove these bloody insetrts cheers man
hey all got me new rimz on work vs-xx dont look to bad
Skyline model = r33
Wheel diameter = 18
Wheel width = fronts 9,rears 10
Wheel offset = fronts +30 with 15mm spacers, rears +25
Tyre size = fronts 225,40 rears 235,40
Modifications to fit = none as yet, fronts scub a real lil bit just going to pull them out a lil bit
yeah they are 9inch rim +30 and 15mm spacers so yeah would be +15
im going to pull the inner guards out and pull the guards out so ill have planty of room
and yeah looks mint niskid CHEA BOI
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • A mini mini-gun.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
