Dont run staggered setup on GTR...and get the 10s +22 with a 265 tire. Should all sit in nicely front and back. Sorted.
Have a look back at my pics of 32 GTR, they are 10s all round +11R and +12F with 265s all round. Yours will sit in a full cm in comparison.
It's rolling diameter of tyres that have to be within 2-4% (can't remember exact percentage) otherwise ATTESSA stuffs up.
Width and offsets aren't the issue, a friend told me about a 34 GTR had 4wd issues and mechanic lined all 4 wheels and noticed 4 tyres are different (all are purchased brand new in same size all round), that was enough to stuff the 4wd up.
ah yeah, iv heard of that with the ATTESSA. Not about width differences tho. Having said that it is easy to changing said rolling diameters by unknown quantities as as 225/35/18 is not going ot have the same rolling diameter as a 275/35/18 right?....
does anyone know if 19x10 +20 will sit flush with r33 gtr guards?
It'll fit easily providing you low it.
also what size spacer to make r34 gtr wheels it sit flush with r33 gtr guards?
25-30mm spacers + low will have this wheels fit flush in 33 GTR.
Thanks
yeh wont fit that under stock front guards without stretch/camber/guard bashing.
i think its important that people dont just say "it'll fit fine" unless it actually will.
fitting and been made to fit are not the same. :thumbsup:
im considering putting 18x9+15 F and 18x9.5+22 R on my standard guard 33
any advice?
Seems like a pretty nice fit to look aggressive on standard guards
will need front guard liners removed, all 4 guards rolled, and 225/40/18 fr 235/40/18 r
guards may need a lil pull, depending on height
depeneding on how much camber you are running and how low you are id say you will still be able to get 255's on those in the rear...
iv got 18x9.5 +36 with 275's. As little camber as the standard arms offer + pretty low n there is heaps of room. only just needing to roll the guards...
you can put better 235's on there.
a high quality 235 will give more grip than a cheap 265
agreed. I think alot of people make this mistake.
But a sticky & fat tyre... :)
that is my new 275/35/18 Toyo Proxes4 on a 9.5" rim (+36). Minimum camber and lowered a fair bit (bodykit is 14mm at lowest points on the front lip and side skirts).
See heaps of room left in the guards but sitting pretty flush
Edited by jjman
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
