should do with guard rolling and even some camber. Should look good.
Do a search for 'volk' int he thread about best looking wheels on a skyline and im sure you will find someone else who has done it...
Will front 19 x 8.5 +27/ rear 19 x 9.5 +24 fit on a r33 GTST? The rims are Volk GT-Cs
Yes. The rear lip will tease just out the guard. Maybe by a cm or so.
The front will sit inside the guard by a smidgeon.
I'm speaking from experience aswell. My rims are 8.5 +25 and 9.5 +25
Edited by Granthem
I know its been done to death but...
My ECR33 currently has 17x8 +35 F 17x9 +38 R which sit totally safely but look a little weak.
I am looking at some 17x9 +25 wheels all round
Current ride height is 330mm centre of wheel to guard.
I want to run 255/40 on the rear and as little negative camber as possible- will this require much guard work?
Edited by Yeedogga
Just about to buy set of new Lenso D1R rims for my 32GTR
I don't like stretched tyres on rims so looking for right size rims to sit flush with guards without any part of tyres or rims poking out so thought i'd ask you guys your opinions
I can get these 2 sizes which i think would be right for a 32GTR
18x9 +15
18x10 +22
Would the 10" rims fit both front and rear on these cars without poking out?
Now in saying this i don't like the look of stretched tyres either so i would need something around 265 or bigger right?
Don't mind running staggered fitment either as long as all fits under guards
Any help appreciated as want to get it right first time
Thanks for input earlier guys, ended up getting the 18x10's with +22
So next question i have is tyres
Obviously there are so many to choose from but ones i'm looking at are Toyo's flagship T1 Sport tyres
Sizes i was considering were either 265/35, 275/35 or 285/35
I'm kinda leaning towards 275 at moment
Anyone know if i'll have any clearance problems if i choose the 275 or 285 options?
Hey guys.
Any of yous running something like::
Rims: 18 x 8, +38
Tyres: 235/40
all around on the R34 gtt?
my main concern is whether it'll rub on any of the suspension parts, given its high offset.
any help would be heaps appreciated :)
Want to go with something ridiculous! Currently got 18x8.5 +22 and 18x9.5+22 on my 32 gtst. Rears sit flush with guards and fronts not so much.
Was thinking of going 18x10 +10 and 18x11.5+10. Got coilies and front/rear camber adj. so don't mind having to pull some crazy camber to fit them under the guards. Alternatively, I was thinking of going GTR front fenders in the near future but I want that tough pumped/flared guards look. Thoughts?
Lollll your front will sit a further ~31mm further out than your current wheels so I'd say yes you would need gtr front fenders and the rear is going to sit 37mm further out and I'm pretty sure that would require a flare from memory for a r32... But I'm sure one of the r32 guys will clarify that for you! Good luck!!
GTR front guards plus rolling/flaring and 30-50mm rear guards would be required in your case.
My neighbour is attempting to whack 18x10.5 +15 with 265/35 semi slicks on his 32 GTST, he is getting rear guards flaring quite a lot.
Just curious, what wheels are you getting?
Thanks guys! I figured as much. Now just deciding if I'm going to go widebody rear fenders or just go flares...
Wheels I'm planning to get Count Grantleyish are Meister S1's. Love the way they look on 32's
Wise choice.
I've got a set in 18x10.5 +22, pity 33 GTR guards are huge, these look sunken even on standard suspension... Also sunken on my previous 32 GTR which was reasonably lowered.
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
