Nah not you mate, i meant SilverS2, info on his setup would probably help both of us, though if you put 9.5's on with no suspension work your car will look like shit.
+22 on a 9.5 will clear the coilovers at the front from what ive stuck in the calculators, but will have some serious poke without camber, lowness, roll/flare and most likely 225's.
Should be sweet at the rear with just a rolled guard. I think it works out to be pretty close to a 10" wide +18 in terms of fitment.
If anyone knows the final word on inner clearance it would be awesome if you could post it up, pictures would be good as well.
cheers,
Jess
Hey, didnt see this post till now, on the rear the 18inch by 9.5 with 30 offset 245 tyres, was needing rolling, and thats with tein coilovers lowered bout half way i think, sits nice on back, the front was definitely causing problems with 9.5wide and if i was to do it again id be going 9 or 8.5 wide.
i have 9.5 on front 30 offset, 245 wide tyres and it was dramas, the guards cuts up the tyres if its low, ive put some camber on and lowered a bit with rolled arches now, but its just scrapping slightly on full lock, but also due to guy that rolled them didnt do it perfectly but its not a huge problem now.
It all depends how low you want to go, the lower you go you run into problems on the front, with the tein coilovers it goes on like 2 or 3 wheels up a steepish driveway and ends up having trouble scraping and wheels spinning, so if your want the 9.5 it will have to sit medium height .
i think ill try 235/35 next time on front if possible, cause its right on the limits as it is, but just doable depending how low you go with the suspension.
I would say dont go 40 profile on the front , keep it 35 so that theres more clearance in the wheel arch and go less than 245 on front but you'll need them rolled on front still probably. then you'll have a full wheel arch and the widest that you can go and most aggressive offset too.
Edited by SliverS2
hey guys. pretty sure 18x9.5+20 will fit an R34 taxi with a roll a little camber and a little stretch. but would like to be adamant. can anyone confirm this?
dont want to buy the wrong sizes etc
Help please?
Got two options for my 32 gts-t (coilies, front/rear camber arms, rolled guards):
1) 18x9.5 +22 all around
2) 18x9.5 +18 Front
18x10.5+18 Rear
Pretty sure first ones will fit with some camber, however, 2nd set I'm worried will be pushing it too far. Although, I do want something crazy. Opinions?
hey
i've got an r34 with work xt7 18x8.5 +32 and 18x9.5 +38
i don't think the rims suit the car so i'm looking at some xd9's and some others
anyway i'm pretty sure it should be ok but i thought i'd check i'm looking at going 18x9 +30 and 18x10+38, i should be able to get away with those sizes without any guard work?
they offsets it has now are good but i'd just like it to be that little but more flush with the guard
as you can see below it's not that low at the moment, i haven't had a chance to get around to playing with the height yet so i can lower the car as needed after getting the rims so it doesn't scrape on anything
Uploaded with ImageShack.us
yeah at the moment it's just not quite flush on both front and rear by the smallest amount, i can deal with it out a tiny bit on the rear, no 'moderfercation' required lol
Got anymore pics?
I went with similar spec wheels as your current ones, but +35 all round, should sit behind the guards a little (which is what I wanted, as I want to lower the car).
Edited by Converge
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
