Hi guys, thinking of getting some wheels for my r33 gtst off one of the traders. Been reading the thread but still wanted opinions from some of the more experienced members. I was looking at getting the following specs:
18 x 9 +15 for the fronts
18 x10 +15 for the rears
Looking at running 235s for the front and possibly anything above 235s for the rear. I will be purchasing camber arms and rolling/ flaring my guards as necessary. My questions are:
- how agressive is this fitment? I want to achieve the wide stance without overly sacrificing the life of my tyres. I do understand that camber will come into play, but I would like to avoid having to change my tyres every month just to achieve a particular look
- would 235s at the rear be sacrificing traction? If so, what would be a better recommendation? As I said I'm willing to roll/flare and purchase camber arms, so what combination would be best for the rear
Oh and I forgot to mention that I will be purchasing some coilovers also, but won't be lowering the car to a ridiculous height since I have a driveway I have to get in and out of. Any advice would be greatly appreciated.
id be keen to see the results of that combo, thats an inch wider than mine on the back, i dont think you want too much more camber on the back, its got enough already
it would be awesome round a track though.
Mate do you have any pictures of how your car sits? I'd like to have a visual just so I have a benchmark to compare against. And what did you mean about the camber in the back?
Just took the plunge and bought myself some Ame Circlar Spec R in 18x9 +15 and 18x10 +15 from one of the traders (Autotechnik). I'll post up some pics when all the work is done. Probably in a couple of months. :)
you'll need alot of camber in the rear, and the front on stock guards will fit with a roll but will have to stretch
tyre life wont be good at all.
should have pics of my 9.5+13 and 10+9 end of next week.
Awesome, looking forward to the pics. Also I spoke to PhilB (from this site and JDMST forums) and he said that he ran similar specs and for the rear, with a bit of rolling and a flare/pull he was able to minimise the amount of camber that had to be run. So fingers crossed I suppose. And luckily for me the skyline isn't a daily driver so hopefully that will minimise tyre wear. :)
My car for example. Previous wheel: (f) 17x9.5 +0 and ® 18x10.5 +15 lots of camber on the front, something like -4 and stretched tyres all round
Awesome, thanks for the photo blags. Car looks awesome!
pretty sure 10+15 will need fair bit of camber if you are only rolling, my camber arms are on full for the 10+20
So alex, your guards were just rolled? I'll be getting mine pulled and/or flared at the rear so hopefully this will allow me to run less camber. So what is the maximum camber setting at the rear for an r33 (in degrees)?
Anyone fitted 18 x 10 + 15 on there 32 gtr? any photos? modifications required?
was thinking of putting 255's or do you guys reckon definately 265's.
Cheers,
Thanks
did u end up fitting the 18x10 +15 rims, got pics or comments on the fit?
Thanks for input earlier guys, ended up getting the 18x10's with +22
So next question i have is tyres
Obviously there are so many to choose from but ones i'm looking at are Toyo's flagship T1 Sport tyres
Sizes i was considering were either 265/35, 275/35 or 285/35
I'm kinda leaning towards 275 at moment
Anyone know if i'll have any clearance problems if i choose the 275 or 285 options?
any updates? pics?
im looking at 18x10 +15 on R32 R
I'm running 18x10.5 +15 TE37s on an R32 GTR with 265/35R18 semi slicks on them and I had to get the guards rolled slightly and the rear raised a tad.
They stick out a little but look f**king awesome IMO.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
