im starting to think about getting new rims for my car, i have a 33 gtst with stock rims,
i think i will end up getting lenso D1R wheels in 18 inches and thinking 8.5 fronts and 9.5 rears,
not too keen on flaring the gaurds maybe a roll what off set do you guys think?
seen a lot of different numbers going around and it confuses the crap outta me, even used the offset calc, but still not sure if its right!
edit: also on stock ride height atm
edit edit: or should i look at something like 8 and 9's?
Im running D1R's. 17x9 +15 (might be +17, cant remember) and 17x10 +15 on the rears. Just rolled guards and they are fine.
I've got CR Kai's on my r33 that are 18 x 9.5 +38 front and +20 rear. I know the wider track is meant to be at the rear but the +20's wouldn't clear the front brake calipers.
Now that I've put some SK bilstein/whiteline coilovers in it (about 335mm from centre of wheel to arch front and rear) I notice the front is bottoming out inside the wheel arch over harsh bumps, and it isn't even that low!
Tyres are 245 x 35.
Is this because of the offset at the front?
Should I get 5mm spacers and switch the wheels around front and rear?
This is current ride height:
And this gives a better idea of offset difference before lowering:
Edited by copycutter
cripes. whats the handling like with the wider ones at the front?
does it tramline like a bitch or what?
iv never been an advocate of spacers but in this case- maybe...
Handles fine. I can't say I know exactly what tram-lining feels like but it corners well and doesn't understeer or do anything overtly untoward.
So is the source of my scrubbing the offset of the rim?
Just put new wheels on the front today. They scrub into the fender lining at full lock or going over pot holes.
What are your opinions on removing the liners? Bad/Good idea?
whats the specs on your front wheels?
just leave them in, helps keep the chassis/guards clean as well.
a little bit of scrubbing on the lining doesnt hurt, only when it scrubs on metal and starts chewing tyres then u got an issue lol
my splash gaurds are still in, 18x9.5 +30 only sometimes scrubs on full lock.
Fronts are 18x9+15. Just an update the scrubbing starts at about 1/4 to 1/2 lock when turning right instead of the full lock as i mentioned before.
The left doesn't seem to scrub from what I've noticed, though it's hitting into the fender when going over uneven/pot hole roads and tiny amounts of rubber are getting sliced off :(
I think the left front side is slightly higher then the right. Just seems weird as fender on the right isn't eating into the tyres, maybe its a camber issue?
edit: typos galore lol
Sorry my mistake I've got +38 rear and +20 front which is why the fronts are pumped out. Can anyone tell me if that front offset at that ride height is what's causing the wheel the scrape the liner over harsh bumps?
Im thinking of going 18x8.5 + 32 F with 225/40/18 and 18x9.5 + 38 R with 255/40/18 for my R34 GTT, from what i heard theres no need for any mods to make them fit.
Just need confirmation before i make a purchase, thanks :)
I'm certain these should fit fine without mods. I've had 18x10+22 on my rears with no mods, except until I got wider tyres :(
Looking at a set of rims at the moment their:
17x8 +45
17x9 +35
what would these fit like on an R33?
(Help would be much appreciated as I know very little regarding this)
http://www.boostclassifieds.com.au/advert/766888-Stm-Lightweight-Racing-Rims-1739-for-Sale.html
(link to the wheels in question)
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
