ok another one for you guys, i didn't end up going down the d1r path but i can get some Grid R's in 18x9.5+22 and 18x10+15 tire wise there 225's i think.
Just wanting to know how they will fit, As stated in my last post my car is fairly low & has rolled front & rears, guessing ill need to take out my inners/liners as they scrub now just past half lock. will i need to pump the rears?
cheers
and finding out what your current wheels are would make it really easy with a few measurements.
it should be written somewhere on the back of the rim/spoke of the wheel. Concentrate more on getting the right offset than getting 10" wide wheels
I found out that the 10" that im looking at are +22 offset. My car is standard height atm and has standard guards. You reckon they will fit ?
Skyline model = R32 GTS4
Rim Model = Enkei RPF1's
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +35mm
rim fouls on caliper, i was told these rims would fit and i dont really feel like buying spacers. does anybody know what dimensions will fit a r32 gts4?
Just out of interest, is it necessary to remove the guard/wheel arch liners out if you are running decent size wheel & tyre or lowering a bit?
My car isn't what you would call low at all, but because my suspension isnt race spec coilovers (they're bilstein/whitelines) and they aren't rock hard, I get scuffing when I go over a hard bump or turn real hard up front.
Or do most just sort it out with camber?
Wheel width = 9"
You need a bigger 'X-Factor' i.e caliper clearance this changes from wheel to wheel and is not dependent on wheel width or offset.
For instance I have a set of Evo V Enkeis and a set of Work Meister M1Rs. At 17x7.5 +35 my Enkeis have more brake clearance than my 18x10.5 +15 Meisters due to a different X-factor.
Edited by Hank Scorpio
Skyline model = R34 25GT Sedan S2
Rim Model = TE37's
Wheel diameter = 18"
Wheel width = 9.5"
Wheel offset = +22
Car sits standard at the moment but looking to lower after wheels are on if it is even possible.
Whats the most practical wheel size/type that won't cause any rubbing or require me to do any modification and what is the most plausible that won't cause me any grief such as clearing callipers etc.. i was thinking 235/40
Edited by Bo Bo
Looking at getting some new rims for my r33 gtst, Im not keen on having to get guards rolled or pumped and want to have the wheels sit flush for legality.
I have been told by a few people to look at 18x9.5s all round in offset of about +30 to +38 or f 18x8.5 and r18x9.5 in similar offsets.
Ideally, I'd like a non staggered fitment and to run something like a 235 or 245 with maybe a 40 or 45 profile. However if that causes fitment issues in the front then I'm happy to go 8.5s in the front and obviously a skinnier tyre to suit.
Just wondering who has run wheels in these sizes/offsets/tyre sizes on a 33 gtst?
Any other opinions on the above are appreciated as well
as to legality it depend on what state you are in.
18x8.5+30 and 18x9.5+30 will fit but you'd still wanna roll the rear guards
9.5+30 all round will look better but you will wanna be looking into removing the guard liners if you want it low.
235/40/18 (but if you wanna be legal 245/40)
Skyline model = Laurel C35 Club S (Skyline in a tuxedo :whistling: )
Wheel model = Work Meister S2R
Wheel diameter = 18
Wheel width = Front 9, Rear 10
Wheel offset = +35
Tyre size = Front 245/35, Rear 255/35
Modifications to fit = Rolled gurads, -1.8 camber front, adjustables with spring upgrade (10s&8s) so not toooo much wheel travel
Thanks for the advice, what if I went 9.5 +38 all round with a 245/40?
From what I can tell the rears will sit pretty much flush with the guards so perhaps the only concern will be the fronts ?
What up sau
Im about to get a set of xxr 527's which are 18 x 8.75 +20 all round and my question is will the rear rims be a bit small for the rears or will it be ok, planning on running 235/40 all round ,
any suggestions please cause im planning on getting these tomorow
Edited by 33VOM
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
