car wouldn't be lowered, or ever so slightly.
would adjustable sway bars, front and rear help at all?
so the lower the offest number, the further it sticks out? So the +38's would go up front and +25's the rear?
i'd be thinking 265 the rear tyres, at least 255.
someone previously mentioned removing the inner guards??
The rears: 18x9.5 +38 is fine
The fronts: 18x9.5 +25 no way. U will have better luck sticking to +38 but will probably still be rubbing on the inner guards.
what bout +38 up front with 235's.
and +25 for the rears with 265's?
i read in a prev post about removing inner guards, would this be an option for the fronts running the +38's?
and is it dodgy to be running the exact same size rim for the whole car, for a RWD car?
+30 on the rears will stick out..+25 will stick out more!
Removing inner guards normally only required if you're lowered a fair bit. (dodgy)
lastly, your car came standard with same width wheels all round....its not dodgy :(
If you HAVE to get those wheels, then 18x9.5 +38 all round...235 fronts and 265 rears.
personally i'd try and use 8.5 at the front +30 max.
how would these fit on a r33 gtst that is lowered though not excessively
WORK XD9 - MAGNESIUM GUNMETAL -
5 X 114.3, 18 X 8.0 - OFFSET +28
5 X 114.3, 18 X 9.0 - OFFSET +30
yes yes, are rims able to be "modified"?
If the centre is free from the rim (bolted together) THE SKIES the limit, except for maybe your pocket.
We have a guy in Sydney that will make anything, into anything, but bare in mind that a custom wheel from him will cost about $400.00 each, so at $200.00 per rim (inner or outer) it might be cheaper to buy a new set custom made ............................. maybe?????????
I recently had these BBS Lorinser wheels modified. Had the 5 stud Mercedes pattern welded up, re drilled 4 x 114.3 & steel inserts fitted, 2 x new inners made widening an inch in and 2 x new outers to match fronts and all up it was less than a grand. I now have track rims (3 piece) and only need to replace what may get damaged, on each wheel. Not replace the entire rim.
Cheers, D
  • Like 1
Just a quick questions im new into skyline. im going 2 get r32 4 Door. can someone tell me wat is the widest wheel fit into 4 door. is 18 x 10 wheel will fit into Rear ? juz want 2 know wat off-set is the best. i know i have 2 rolled the guard.
Thanks
Mick
Thanks
Mick
Why don't you research what tire size your going to use and get a wheel they fit instead of arse about face.
On a 4 door Skyline why would you want 10" wide, V8 supercars are running 10's all round, why would you want them that big on a street car.
Seems like a huge waste to me!
Cheers, D
Quick Question:
Would These wheels fit a R33 GTST & what mods would be required to fit them eg. rolling the guards
Front
20 x 9.5 +20
Rear
20 x 10.5 +22
I think they would need abit of work but im not sure!
Cheers
Anyone?????
  • 3 weeks later...
Skyline model = 32 gtst
Wheel diameter = 18
Wheel width =8f & 9r
Wheel offset =not sure 30 something maybe...
Tyre size =235/40
Modifications to fit = i do have m sports wide body front fenders but the front would still fit if i didnt have them rears hang out the gaurds abit and i need to lower it looks like a 4WD now!
rear tyres just fit HUGE stretch!
al_r33
Hi all. Just thought I'd post this up as I have these fitted to my R33 25t after a 6 month wait for tyres!
Skyline model = '97 25t
Wheel diameter =19"
Wheel width =8.5" front 9.5" rear
Wheel offset =+25
Tyre size =225/35R19 Front, 265/30 rear (Dunlop Spormaxx)
Modifications to fit =Rear guards lips rolled. I had 235/35 on front when I first got these and had too much guard rub up front. 225/35 has fixed the problem it seems!
For what you want -
Front
20 x 9.5 +20
Rear
20 x 10.5 +22
The front guards won't accomodate that size (rims would stick out about 17-18mm more than mine) , new guards, or pumped guards would accomodate.
Rears - small tyre stretched over may fit, but my tyres currently sit just behind rolled guard lip when suspension is compressed, to be honest I'm suprised they don't rub at the rear! I think the actual rim would just stick out past the guard. So with a slightly bigger rims being closer to the guard, I doubt strethched tyres would work unless your whale is ridin rather hi. Pumped rear guards should do the trick though, or grafted R guards.
Edited by rocketboy
  • 3 weeks later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
