I run 18x9.5+12 w 235/40/18 allround, tyres tucked. not cambered and not flared... I get no scrub... it's all in the guardwork
I cant see how it would be truly working without sticking out a bit n at least 1-1.5 degrees of camber...
Also stretched tyres are something that i dont really count as admissable technique for something fitting.
id be keen to see pics of that Joey... No wait you do at the top of page 86 n you indicate a +22 offset, not +12 as here though.?
I can see that setup being +22 (and ill say it looks reasonable) but not +12...
Edited by jjman
Thats the thing with wheel fitment and this thread.
The problem is everyone has an opinion and what's really missing is the key aspects to fitment. How much guard work you prepared to do, how much camber do you want to run, what size tyre do you want to run and if you like stretch or not.
Until these things are sorted hard to recommend an offset or width.
18x9-1 215/40 Front -3 Camber could get away wtih a 225
18x10+18 225/40 Rear 0 Camber i do have a 25mm flare could get away with a 235
Going to dial in more camber on the rear probably -2.5 and massage the guards abit more as i'm going for some crazy fitment.
Mind you that the car is track orientated and i wouldn't recommend running what i plan on doing on the street as you'll be hassled and defected straight away haha
Just ordered a new set of boots for my 32 gtst.
17x9.5 + 18 front
17x10 + 18 rear.
Will let you know how i go ;)
Well i've only had a chance to test fit so far, but it's going to be abit of fun!
post-75263-0-46425200-1339733957_thumb.jpgpost-75263-0-50023100-1339733934_thumb.jpgpost-75263-0-49378600-1339733979_thumb.jpgpost-75263-0-15323700-1339733999_thumb.jpg
that was a +25, current rims are +12's and of course they stick out a little... never said they didn't.
tyres aren't really stretched, we are talking a 235/40/18 on a 9.5 - it's within the required specs of most tyres i run and only 1 size smaller than ADR's reccomend (245/40 legal minimum)
What suspension joeyjoejoe?
greddy type s 6kg rear 8kg front (wound up to max) superpro castor bushes front and superpro camber bushes front and rear. selby's swaybars front and rear. superpro pineaple bushes (set for grip).and gteck rack spacers.
18x9.5 +15 with a 235/40 18. guard lip rolleds up 100%, camber is set at - .2 with whiteline camber arms, about 3mm off guard, will put camber to -1 before the next track day. front is -2.5 camber, hits guard liner, no big deal
Wont that require a lot of guard work?? I am not a fan of the stretched look....so want tyres that sit flush basically...right up to the ends of the rims if you know what I mean...also what about rubbing on full lock??
can anyone tell me what sort of rims these are??
i'm sure i've seen them a million times before but never saw them on an r32 till now.. and would definitely consider these after seeing this!
look for photos of r32 GTST with R33 GTR rims (17x9 +30)
Will give you an idea.
Here is a photo of 18x9 +30 (username: timr32gts)
Looks like xd9's ....
indeed they are! thank you sir.
another inquiry. the following are pics of an r32 i was considering buying back in 2006. i have a question re the rims on it.
i know they are an american brand: HP design. model - HPR5
the ones on this particular car were 18", but i don't know what width that is on the rear. from my own research, every 18" example of them i've found was +38 offset and was available in 18x8 & 18x9 (+38 on both). so i'm picking the fronts are probably 18x8 but can anyone shed some light on what width those rears are? i've been a bit apprehensive about getting 9" rims for the rear of my r32 because i know a lot of the time there is guard/lip work involved, and i dont want any of that. but i was thinking 9" with a +38 offset may work even because it sits inwards just that little bit further than most other 9's? because i'm pretty sure this particular car had no guard work done. and if i can still get the rear down to a nice height without any rubbing that would be awesome.
this is pretty much the exact fit i'm going for, so just want some insight to whether the rears are 9" or 8". these are the most telling pictures i have of it.
chur!
25396297 full
25396196 full
25395936 full
thinking of getting work meisters sp1 3pc wheels.....want to run 18 x 8.5 +29 fronts...and 18 x 9.5 +24 rear....is that ok for the rear??? other option is +37
THANK YOU
go the +37, +24 will be pretty mexican. +37 will be flush with the guard and look great (will require rolling/cutting the arch guard on tho unless u want to run excessive camber or if the car is lowered).
+37 and some good 265's or 275's and you are in looks and traction heaven...
Edited by jjman
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
