Sydney roads are f*cked. For one of the "best cities in the world" they should really improve the road system. I didn't realise how f**ked it was until I got coil-overs and set the dampening to the softest setting and still bounced all over...
i wouldnt list Sydney that highly.......
as for the dampening thing. i thought the same thing.....soft settings = soft ride.
seems i was wrong, on soft the bounces seem to continue on. ive got mine wound about half way to hard on the front. and a few notches less on the rear and it became alot more drivable on my crappy ass main road.
XXR 527's for a r34 gtt
18x9.75 +20 or 18x8.75 +20?
Which would be the better flush fitment (aggressive but not a ton of camber)?
Guards will be rolled and lipped btw
18x9.75+20 will poke fronts, inset rears. Won't need camber, will only scrub on full lock.
So would it be better to run 18x8.75 + 20 up front then? Or would that be too flush/not very good stance?
I am about to buy 18x9.5+22 fronts. The way I see it, I don't full lock often. I am looking for form>function. But yeah, if you go the 8.75, you will be 12mm LESS poke. Depends if you want it to look good, or be functional. But I would go wider on the rears or think about bolt on spacers if you want some flush. I am going 18x10.5+30 rears, I don't think that is poke enough, but I haven't bolted them on to see, I am going off a mates car that has 18x9.5+20 all round and his rears are inset.
Does anyone know how
9.5 +22 (front)
10.5 +30 (rear)
Will sit on a gtt?
Too aggresive or nahh?
If you took any sort of time to actually read this thread, you will realize that I am doing that exact fitment. I wish people would actually read the thread before posting. I went through 95 pages of this thread before I asked any questions. Took me a few hours, but at least I know what I am talking about now. Anyone can tell you it will fit, but you want to get the fitment that YOU want, not what other people say will look good.
Either way. With that fitment, you will NEED the guards rolled, front and back. With no camber, you will poke fronts, and hopefully poke rears. Only by about 5mm, but poke none the less. Run stretched tyres, and lower the car onto them, and you will get some nice stance. I have a black gtt, going varrstoen 2.2.1 (te37 copy) rims. 225/30/18 fronts, 245/35/18 rears. You will get scrubbing on full lock on the plastic lining inside the front arches. If you don't have coil overs, get them.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=396593
That is 18x9.5+20 all round. With that fitment we are wanting, fronts will be inset 2mm, rears will poke 3mm more.
I have ordered my rims already and I plan to have them on in 2 weeks on my R&R week (I am up on site for 2 weeks). Pics will be up immediately. If you want to wait until then to see the fitment, and judge for yourself.
http://www.skylinesa...ttach_id=396593
Alrightty, cheers mate, yeh i just could not be bothered going through all the effort!
but thanks heaps for the reply, i'll be looking forward to you posting up pictures soon!
With that set up it sounds like a lot of aggressiveness, me likey!
Anyone have this problem? I've got a R33 GTS-t with R33 GT-R wheels on it. 17x9 +30 all round.
Seems like on 'near' full lock the wheel smashes into the suspension arm.
Luckily at the same time, I spotted the bracket holding the brake about to fall off, quickly bolted that back up!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
