Just looking for people's opinion's on the latest microtech, whether you use it or not? I know the old ones didn't use a closed loop so they were pretty bad on fuel and were bad on cold starts but i'm told by my mate that the new L series of microtech's now use a closed loop and are much more programmable etc.
He can get me the LTx12 and it will be going on my Rb20 then onto my Rb30DET. The main reason he wants me to get it is because he is mates with the South Australian distributor and can get me it at a very good price!
I have been looking at the power fc but if they really have improved i think i will get one because he can get it cheaper than a power fc!
https://www.sau.com.au/forums/topic/84261-opinions-on-latest-microtechs/
If you have a Nissan then definetly spend the extra money on a Power FC. Apart from Autronic (without breaking the bank) they are the greatest ECU for a Nissan, Microtech have made slight improvements but not enoguh to better the Power FC.
:angry:
definatel microtech most of the top cars use them
im definately happy with mine
i have also supplied and fitted 7 microtechs with no problems
mmmmmmmmm 2 very opposing opinions, this is going to make my decision very hard. so is your fuel economy pretty good compared to the standard ecu? and how are cold starts etc? if you can tell me any things that make the microtech more appealing over the power fc please tell me!
On an oooold microtech of mine the cold start was perfect. This is the hardest part of tuning an aftermarket ECU as you only get one shot at it every day and it could get costly. The advantage of the PFC is that it retains the same factory settings for cold start etc and that makes tuning alot easier.
It's been said a number of times, but I'll reiterate: an ECU is only as good as it's tuner.
You know the best way to chose an ECU?
Find a tuner that you trust, and ask them. If you find a tuner and go, tune this, and they have never used it before, they will obviously give it a go, but it probably wont be as good. And you have to trust the tuner, its a bit like a doctor, you wouldnt go back if he gave you panadol and a slap on the back if you broke your hip in 3 places.
Thats what I think anyway. Also it seems most people are using the PFC as its a plug and play pretty much, from memory wolf, haltech, etc all do plug in's now too.
I have the LT12 in my R33 and wouldnt go back. The reason I chose this one is my tuner reccommended it and knows them really well. I get 9-10km per litre but the cold start was a little bit hard to get right at first, but an air temp sensor sorted that, now its good. Its much of a muchness find a good tuner and ask what he wants to tune.
ye its a 32 so the cheapest i've found it $1380 and the microtech i can get is $1000 and both come with a hand controller. i think i will go the power fc becuse the tuner i want to use prefers power fc's!
I have a lt12s microtech in my R33 gtst and i am extremely happy with mine.......they actually cost more than the power fc's and make more power....
The power fc's still use the afm where as the lt12s dont use one at all...it is replaced with a bit of fabricated piping, so is less restrictive.
It also has more tuneability than a power fc.
I gained 50rwkw from installing the microtech but knowing a good tuner that knows microtechs helps. My car had 160 rwkw and after installing the microtech i got 209.1rwkw at 12psi with the stock turbo!!!
I have no problems with coldstarts as i had an air sensor installed at the same time.
I know a guy that installed a power fc in his R33 gtst and has got a high flowed turbo and only has 211 rwkw at 15psi and before he had about 180rwkw...... a gain of only 31rwkw.
The extra money for the microtech is definatly worth it..
Edited by lismo
Hahahaha....
That is one of the more stupid things I've heard. I'm not sure if you are serious or are an aspiring stand-up comic genius!
You'd be good at the latter.
Mate, ECU's do NOT make power. The tuning of an ECU does that. If you have say, 2 x 200HP cars. Both identical. If you install a Microtech to one and a P-FC to the other, neither will make more power than each other. I'm sure good P-FC tuners will be able to tune an ECU to make the same power as a similiar car with a Microtech. Also, you may of had such a large gain, but the person you stated that only had the 31rwkw gain with the P-FC probably got much better economy and ran a safer tune.
I would go the P-FC, simply because most tuners are more familiar with them when it comes to Nissan performance cars. Another advantage of the P-FC is the knock sensor, could come in handy one day, y'know...
Anyway, I hope you make a good choice, no matter what ECU you choose. Good luck
To NISMO
Im glad you find it so funny!!!
My car is absoulutly fine, never had problem with it and i dont find it any less economical than before the install of the microtech.....and yes it obviously produces more power as i found a very good microtech tuner.....
Its just my opinion as every one is entilted to one...and i do think that microtechs are definatly better than a pfc...
To RB MAN
If your in Brissy i know of a good microtech tuner and he isnt as expensive as most tuners.....pm me for details if your interested..
Another vote for going with the tuners choice.
My tuner (P.I.T.S) said PowerFC or Wolf3d. I tried the Wolf and am extrememly happy as the tune is perfect. Everyone who's been in my car has commented on how well it runs for a moderately modded Skyline. Since the tune and running 16psi I have never heard it backfire at all or splutter even once at high revs. This however, is due to a good tune, not a good chip. I'm sure I would have had the same results with a PowerFC.
It's all about the tune!
I hear what you are saying, but its not really true....is it??
The quality of the ignition and injector drivers surely make a difference. My old Microtech wasnt too strong in the ignition driver dept, as the thing would go up and down dependent on the load on the electrical system etc, headlights. wipers etc Also the processor speed with repsect to injectors etc surely makes a difference.
In the wash up it may not be a lot of difference, but i would be surprised if you put two ECUs on the same modded car, that they both would be able to handle the same amount ignition and boost and power wihtout having to wind fuel in and ignition out. Also certain ECUs can surely be tuned closer to the brink of detonation as they have finer control and control loops/channels etc
... I think. i repeat, think...im not saying you are wrong....but thats a few things i considered when looking at ECUs
I got the same gains as you with an safc11 so have alot of other people, should we be claiming the safc is the superior managment??
Edited by otto
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
