  • Replies 64
Posted Images
  • 3 weeks later...
Not to hijack the thread, but:
I've been looking for a gts-t sticker for my car for _ages_ :( It needs to be the R32 one, though.
I also want a big red white and blue 'DATSUN' top-of-windscreen sticker (like you used to see
on the old 1600 rally cars and the old bluebirds). Anybody that can supply either of these please PM me.
And to add my opinions:
To the original poster - whatever floats your boat. Put as many GT-R badges on it as you like.
To those that are "offended" - get over it :) His car is there to make him happy, not you... as
long as he's not trying to defraud someone (e.g. by selling a "GT-R") who's he hurting ? I'm
much more offended by those stickers promoting racism or religion...
Regards,
Saliya
https://www.sau.com.au/forums/topic/84309-please/page/3/#findComment-1578041
FARKEN OAF MARS
fookers sticking $5 GTR badges off eBay on their stock GTST (but especially the NA GTS!!!!) nuggets are total lamers
put a GTR wing on, kit and a grill on to make ur car look meaner but don't try to illusion yourself of having an actual GTR by putting a dodgy sticker at the back
just get a real R32 GTR they are affordable now.
Edited by DarKZer0
https://www.sau.com.au/forums/topic/84309-please/page/3/#findComment-1580655
FARKEN OAF MARS
Mate, on my gtst type M I've got GTR rear wing,front bar,Vspec2 lip for the bonet,GTR badge (original $65).
O and also I've cut nice and shiny GTR key on top of that! :P :lol:
https://www.sau.com.au/forums/topic/84309-please/page/3/#findComment-1608747
Here's one for ya. I was in a service station the other day and was approached by a guy who asked me if I might be able to help him fix a problem with his GT-R. No problems !!
I drove over to where he was parked and parked next to him and had a quick glance at the car as I got out of mine. A dark blue R32 GT-R..... No worries....... We started talking about the problem ( engine idle hunting ) and I said, no worries, let's start by looking for the obvious things.......open the bonnet and we'll have a look. He pulls the latch and I open the lid and put the stay rod in place only to see an RB20DET :P
I stick my head around the side of the car and notice that the gaurds are GTS ones. Then I look at the compliance plate and notice that it has the following engraved upon it "GT-R" right next to the VIN which says HCR32XXXXX
( I won't say who did the compliance / engraving but it was a pretty well known import car seller in Sydney ).
Shortly after explaining to this guy that he actually owned a GTS-T, not a GT-R and what the differnces are between the two this guy freaked out. He told me that he thought he scored a GT-R for great $'s ( he paid $19,600 ) and then shortly thereafter, he went totally red, jumped in his car and took off.
He had the GT-R badge, wheels, wing and front bumper and was convinced she was an "R" so not all people are tossers. There's at least one person out there who just didn't know.
And if you're part of this forum mate, I'm sorry I had to break it to ya and all the best getting you're $'s back.
https://www.sau.com.au/forums/topic/84309-please/page/3/#findComment-1611683
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
