thanks for that mate...ok guys so i took that vid when checkin the car out...
it was on a cold start, ice cold engine basically, hadn't moved. had just been washed and was basically still a bit wet on the body. umm, that was just AFTER it had been revved n stuff. when it was revved that same color smoke just got a bit thicker...then died down to what u see in the idel vid..
so what are your thoughts? bad? nothing to even worry about?
Let me clarify ... this is a cold start, you revved it a bit, but essentially this is idling while it's still cold?
If so, this is completely normal (as has been stated a few times already). It's simply condensation in the exhaust pipe.
Let the engine warm up for 15 minutes then see if there is still the same amount of smoke.
