Hey,
My Apexi AVCR is giving false boost readings
eg. it says 1.7bar when my boost guage is saying 1.2bar,
Also the other day when i turned the ignition on the solenoid valve was making really loude ticking noise, as soon as i turned the boost controller to off it stoped
Is my AVCR stuffed??? I checked all of the hoses and it all seems fine.
Thanks
- Luke
Make sure you AVC-R Pressure sensor is mounted horizontally and not on an angle, as this can cause incorrect boost reading. Also make sure your duty cycle is not too high, that will cause loud clicking noise when you switch on to A/B and could actually be reading right.
You boost gauge could also be out.
Edited by BBQ
