Hey,
Im having problems with my car at idle, It idles up and down:
eg. 1000rpm,(2 second grap) 1300rpm, (2 second gap) 1000rpm, (2 second gap) 1200rpm etc.. Some times it stops & idles fine (for a good 15 seconds then up and down again)
Its set to 1000rpm on the PFC.
Mods: HKS turbo, Z32 Air flow metre, 460cc RX7 injectors, Power FC.
Any help would be great,
Luke
Is your turbo high mounted?? Problem with mine is the afm is too close to the turbo and the blades chop up the air around the sensor if its too close on deceleration and the idles starts playing up...you need a minimum of at least 1 90 bend roughly between turbo inlet and afm..put some distance between the two. If you dont have a high mount then im not sure what the problem could be..maybe ur idle control valve needs cleaning or maybe theres a electrical fault...wires or plug??? Might be worth looking at.
My turbo is low mount (factory location), & is the same distance to stock. but there are no bends in it, it sits farly straight though, only a slight bend it!
I have another idle controll sensor, i think ill try that.
- Thanks
Luke
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
