thanks marcus and ST113, you have confirmed my fear that the +12 9.5s will only fit on 33/34 GTRs. bummer.
I will continue the search. I think the 18X9.5 +20 should be ok with a smaller tyre, say 235?
Atfer a quick search, I found that a few people have fitted 265/35/18 tyres to R32's, so you may not need to go to 235's:
http://www.skylinesaustralia.com/forums/in...showtopic=79629
http://www.skylinesaustralia.com/forums/in...showtopic=84208
Using a +20/22 would be a safer bet as you could always decrease the offset slightly if need be.
I'm still trying to work out how to fit 18 x 11's :(
Edited by NXTIME
mmm tasty.
I have 245/45/17 all 'round at the moment so it seems i may be ok using a 245 on the 18s but even with the current set-up on hard lock everynow and then they just touch the plastic splash guard. :(
Hi Richard,
Yes my Volks are 18x9.5. I can't recall exactly what the offset is (they are stored at my dads house ATM). I'm fairly sure they are +22 as per the Rays fitting chart for R34 GT-R. However, as the fitting chart states
Because it extends from the fender, the case of installing please note sufficiently.
Basically they extend out of the front fenders on R34 GT-Rs, and *I think* both front and rear on R32s but its a little hard to tell as I only test fitted them quickly:
A few more piccies from various angles here.
Lucien.
I'm still trying to work out how to fit 18 x 11's :P
I have 265/35/18's on my R32 GTR with 18*9 +24 rims. They are a perfect fit with no rubbing on full lock.
Regards
Andrew
Thanks Lucien. I think the ones you have are the +12? cause they seem to stick out quite a bit at the back. very nice wheels. Looks like you will need to lower the car ;) and roll the guards :unsure:
My dad is going to call me this weekend: I'll ask him to confirm.
Edit: I should also mention that the sticking out effect is probably slightly exaggerated by two things:
1) I have no idea what the camber is on my car ATM.
2) I only installed the TE-37s on one side of the car: the other side still had the stock 16" wheels on.
Richard, why did you bid on the CR Kai's you crazy bastard. They are a cast rim.. I would stick with forged rims if I were you - those were cheap for a reason. CE28's are where its at in that style.....
Oh and the 34 rims are expensive because they are a lightweight forged rim so yes you can get a Rays forged wheel for the same amount but its about the same from a performance point of view, its all about your preffered style and on the track the 34 rims make as much sense as any.
Edited by sewid
hehe, yeah I know they are cast, but apparently they are still quite a strong rim as they are made by their new casting process, spposedly near the strength of forged but without the cost. :P
The 34 rims are nice but quite common now on 32s, i'm after something a little different.
I'm guessing you are back in town now? we should catch up soon, even just for a coffee/beer. send me a pm or even give me a buzz.
I'm going to run 265s on my R34GTR rims when i get them.
In a wheel related question, while no doubt the 18x11s look TOUGH above, i do wonder about the 3 piece Japanese type wheels (like the Works and SSR Professors) and their ability to swallow a 365+ diameter brake disc.
I know this is not a big consideration when buying wheels for most people, but I would look SERIOUSLY at max disc and caliper clearance before spashing out on a set of rims. The TE37s are awesome as they will take a MASSIVE rotor in 18s.
It's a consideration as you don't want to have your nice sparkly 18s only to find down the track that you won't be able to fit the 365mm rotor APs you bought because of wheel clearances
Cheers
Ok guys I just have one little question. I had a look at the calculator but I can't use it I don't have enough information.
R32 GTR 17 x 9 rims should a +22 offset fit without needing spacers etc? I have 17 x 9's on there now but they are the wrong offset and need spacer plates all the way around. Just want to make sure before I order these new rims, that the +22 will be ok? There are no sizing charts, previously I wanted SSR Professor's for it and the relevant sizing was +19, and when I spoke to my tyre guy he told me +25. I'm now getting different rims due to SSR going bankrupt, and the imitations of the Professor don't come in 17".
Thanks :D
Thanks :P
i have 17*9 +22 Enkei RP02 on my R32 GTR with 235's on them
there are no spacers and look fine, they dont stick out too far and they dont sit too far inwards either
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
