  • Replies 160
Posted Images
the only things you would use from a complete front cut would be stuff like the bonnet, reo, front bar, hinges etc, which kinda defeats the purpose of buying an entire front cut especially since the R34 GTR front cut is not the cheapest thing to buy – even more so just for some of the body parts.
the side guards need to be the MASA or CCubed guards, i can vouch for the CCubed guards being the highest quality. and plus its very hard to find a complete R34 gtr front cut - or even a stripped R34 GTR front cut. I havnt heard great things about the MASA guards
if you're going to do it, weigh up the costs and time it takes, because its not cheap and it doesn’t happen over night...
I payed approx 4000 US-dollars for my GT-R33 frontcut, there was a 5 speed manuel gearbox, RB25DET-Neo engine, complet HKS suspenssion, front and rear, complett dashboard, and all the parts in the engine room.
I can get the GT-R34 frontcut with the RB26DETT engine for 8000 US-dollars.
Edited by Stagea Denmark
  • 11 months later...
anybody seen these guards on ebay??
http://cgi.ebay.com.au/Bodykit-Nissan-Stag...1742.m153.l1262
not a bad buy @ $380. but they would be pretty useless as it makes no mention of any of the required brackets. might be handy if u have already done the swap and damage a guard.
I'm getting interested in starting a conversion myself, just wonderin if anyone knows if the R34 GTT front bar and bonnet would work with the MASA front guards?
Um, pretty sure that is what the Masa gaurds are designed for dood :)
the masa guards are based off the GTR guards, which are wider than GTT guards.
the front bar will likely fit, however the sides will be pulled out a little, which may cause the bumper to buckle a little in the middle.
you also need the GTT bonnet, hinges, latch, etc. as they are different from the GTR items. (unless you want a GTR bonnet, then you will need t0 use an add-on lip, such as the one that east bear offer that fills in the gap between a GTT front bar, and GTR bonnet, http://www.east-bear.co.jp/shopdetail/003013000001/order/)
the guards themselves shouldn't require any brackets, as they are custom designed to adapt the R34 front end onto the stagea chassis.
i'm pretty sure its adapting the lights, etc to the radiator support that requires additional brackets, as they obviously differ.
i know guards dont need brackets. the point i was making is the guards arent much good without the backets required to adapt the lights etc. unless u know how and have the means to manufacture them yourself.
i doubt it, the guards are designed to suit the 34 bonnet, as well as the headlights and bumper.
would be better off having them in metal, but the work required would make it expensive. :banana:
  • 4 weeks later...
  • 1 month later...
Have we come to a final conclusion of what the whole thing will cost landed. And who to use to get it to Oz.
Also is the Masa Kit for the S1 or S2 Stagea?
Buy a Australian made kit for less money, less work and better quality and fitment
www.ccubed.com.au do them
Series 1 and 2 the same
Is this kit just something you have to ask for specialy??? I couldn't find anything regarding it on the site.
Here is a cut and paste from a email from Andrew at CCubed. . . .
The complete kit costs;
-Guards $ 690.00/pr
-Bar reo $ 350.00
-Headlight adaptors $ 200.00/pr
-Bonnet Hybrid $1,200.00
-R34 GTR bar $ 450.00
-Front Lip $ 250.00
-Splitter/Diffuser $ 600.00 (Opitonal)
All these pieces come to $3,740.00
All these prices are for fibreglass (FRP) products.
We can do the bar, lip and diffuser in a flexi version too, so it behaves just like a O/E plastic item, even sounds like them when you tap it.
This kit means no de-gassing of the air conditioning core.
The bonnet goes straight on to the factory Stagea hinges. It lines up with the rubber stops and bonnet catch. As it is a R34 top skin with a Stagea under-skin, so we call it a "Hybrid hood".
The headlight adaptors are moulded brackets which allow the R34's lights to mount to the Stagea's radiator support. You only need to trim a small amount of metal from the Stagea's radiator support to allow the wider R34 lights to fit in position.
We supply a template which allows you to mark out where you need to trim.
To fit them, drive in drive out would be approx another $2,640.00 (plus paint and assuming the car is straight to begin with). We can paint them too, but most people have their own painters.
This price would fluctuate depending on the mounting of any other bits and pieces, e.g. FMIC or Factory SMIC etc that may need moving or trimming to make fit.
The only other things to probably grab would be head lights and the rubber strip which fits between the top of the front bar/grill and bonnet front edge.
We can source these too if needs be.
The kit even comes with a carbon fibre bonnet prop! As you don't use the gas struts on the new hood. Or you we can get your existing gas struts de-gassed a percentage to compensate for the lighter hood.
We've done that on a few cars now when they fit lighter hoods.
Depends if you want to spend that little bit more, or just use the prop.
  • 4 years later...
time to bring a thread back to life.
has anybody looked further into or know about these frankenstein gtr/ stag conversions keeping the stag healights, bonnet and i assume guards?
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
