hi guys my cars currently at the workshop undergoing an operation u could call it, its having a new fuel pump wacked in with a FPR, a new set of injectors, an A'Pexi power FC, and a new Garrett GT30R turbo, so after a tune it should psh about 250rwkw, i have all basic mod's FMIC, air filter and exhaust...
i was just wondering wat u guys think it would run down the 1/4mile, i was thinking low 12's maybe high 11's, is this realistic? any thoughts and comments are welcome..
https://www.sau.com.au/forums/topic/84384-r33-gtst-250rwkw-gt30r/
  • Replies 166
you'll need some wide rubber if its street gear to get 11's IMO.
i skimped through @ 12.1 and that was ~300rwkw on the old motor... 25/GT30.
The most retarded amount of wheelspin as i was using 225 street tyres :D
yeh already got a clutch and i know mine spun in first before the upgrade, about the airflow meter, i was thinking of getting a z32, but am not sure if ill need it does anyone know wat the limits are on the standard AFM?
ive got damper adjustable shocks at front and back, not sure wat brand, but my car sits pretty low. so im not sure wat to set them to wen draging but, hey i guess i can muck around a little on the day make it softer or harder!!!!
Go softer so your car can squat down on the launch, and let your tyre pressure down quite a bit for better traction.
I would go the Z32 AFM as there is the option to select that airflow meter built into the Power FC, which will make the tuning process a little easier. When making that sort of power I think you are better of sticking with a product you know works.
Good luck at the drags, I'd say a low 12 is on the cards.
Edited by PHATGTR
yeh custom as in made specially for me, wow $440 is pretty expensive, i think i might get my mates he is known for supplying good stuff....
but what do you mean by custom ?
Spend the money on a new one mate. You wont regret it in the long run.
After all the mods you've done, turbo injectors etc. Ifm your saying $440 for a new AFM is expensive then its time to sell the car :P
i wasnt saying $440 is expensive i was thinking that the custom made one is probably a better flowing AFM then a z32, which means i have no limits in the future if i decide to push for more power.... and as PHATGTR said i porb will go for a z32 as i have a power FC and if it makes tuning easier then i will get it...
im still struggling to understand though.
how can a "custom" one flow more?
What is custom about it?
Hows does it work with a PowerFC?
Is it a Z32 thats copped up? How would the resolution go on this "custom" AFM?
just interested
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
