  • Replies 166
yeh i am in syd, im getting all my work done by a mate who works with MRT performance, they specialise in wrx's, so i get most of my stuff cheap and he is not charging me much in labour, i will prob get mrt to tune it for me as one of his mates tunes power FC's and he has shown good results in the past..
as for the progress guys, i hit a small delay today, this morning i pulled off wat was left of the standard turbo and started trying to fit the new GT30R, only to find it is too big and hits.. so for anyone out there trying to fit a GT30 u will need a spacer for it to clear any of the engine, so i have to wait till monday, i guess i will get back to work now, i going to fit the fuel pump and regulator....
Post a pic of your GT30R....Id like to see it and compare it to mine. I make 230 rwkw on a high compression motor on pump but with a proper FJ20ET, it makes 260rwkw. You shall no prob making 250rwkw at 20psi. Make sure you upload the compressor cover and the exhuast also includling the cartridge where it has the metal garret tag.
Cheers
ok guys here's wats happening:
for those of you who are thinking about using a GT30R or any of the GT30xx turbo's on their r33, dont listen to wat the sellers tells u... nothing lines up and it certainly does not bolt straight on!!! u will need either to opt for an externally wastegated version with a different manifold or do it the way i am about to, as it is too late for me to change and go for an externally gated setup.
i had to get myself a spacer between the manifold and turbo that is about 1.5inch thick to move the turbo away from the manifold so it doesnt hit it, without the spacer the turbo is too big be bolted on prop, now once that is done the spacer must be this thick as u will need heaps of room to twist the turbo so that the actuator can be bolted on, it is hard to explain, but trust me i tryed every possible measure, it has to be like this..... and finally none of the oil/water lines fit they have to be made up, so suppliers will say it fits but trust me it doesnt!!!!!
I cbf quoting a few points, so i will just state my opinion on a couple of issues raised and hopefully you know what i am refering to. :blink:
1/ At 14psi i honesty do not think you will reach 250rwkw, i think you may require about 18psi.
2/ Suspension plays a big part in drag racing, and if you want a decent 1/4mile time, raise your car (temporarily) to at least std height, this will allow your suspension to have maximum travel. If you have Jap coil-overs then that is a disadvantage, as even on their softest setting they are usally too hard. Remove any strut bracing or roll cage, etc, This will allow the chasis to flex on take off and transfer more weight to the rear wheels.
3/ If you drive like a 40yr old (casual driving style, with the occational squirt, and the rare flogging) then yes, your std motor MAY last 80,000km@250rwkw with std eng, if it hasn't had a hard flogging b4 all these upgrades. But if you like having "fun" and give it heaps every other day, it may only last a week/month/year: Who knows?, just be prepared to build it properly if it decides it's had enough.
4/ MRT, are they the guys that entred Vic. Dutton with a red VY commerdore and a crazy fuel cell set-up in the boot?
Some of the subaru and ford guys make their own custom AFM. This means they take the sensing element out of their original AFM and place it in a tube. Highly technical, they have really taken into consideration the reversions flow criterias/characteristics that the sensor needs in order to work correctly, ie correct throttling and delta approach angles.
We see all sorts of things at work, eg1. a cobra kit car with an EF 5.0L with an induction system about 10ft long with a AFM stuck on the end. There was a resonance created within the pipe due to the throttle and AFM that caused it to surge. The ecu was out of sync with what the AFM was saying it was almost perfectly balanced so that it would trim the fuel in the opposite direction as needed. Long story short if he had kept the original length of pipe between throttle and AFM it would have worked fine and thats what we suggested.
It is possible to tune an AFM based on grams/s vs voltage (MASS transfer function). I do it all the time when dickheads pull the mesh off the GENIII MAF sensor - thats got to be worth at least 25rwkw's!!!!!!!!
Al wat sort of power do think ill make on 1 bar, also i have a two stage actuator so i can set it to 17 psi also, wat u think ill make at 17 psi?
as for the suspension i dont have jap coil overs, my car is low but has a set of damper adjustable shocks so i can soften the back up a little, however im not going to go all out and raise the car just for the drags!!! my intensions arent to build a drag car, i was just curious a s to wat kind of 1/4mile time my setup would run.
GT30 are indeed big..i didn't realise you were gonna bolt it straight up.. NO..i wouldn't bolt up..and there's alot involve installing them..been there and i know what its like..more delays too hey ?
make sure if you were to get a spacer get it laser cut..otherwise there's another option of geting yourself a highmount manifold so your turbo sit higher,..this is actually a better option for me when i fit my turbo,. you will need to change cooler piping anyways,.why not go for it.
and nope..14psi will not do it.. im hitting 18psi with 380rwhp on my gtst with 265 tyres and still get that bad wheelspin.
get better suspension and you're set to go.
yeh i know, um i got around it anyways, it fit with the spacer and some mdoifications to the actuator bracket...
and yeh if i had known i would of went for a highmount and external gate... but hey u learn from experiences...
a GT30 has never been a "bolt up" option.
its double the size of the stocker dimension wise.
I dont think anyone has done it without a spacer plate
As for the power you'll make.
Depends on the turbo. There is nothing to say you cant make 250rwkw @ 14psi.
Its totally and utterly dependant on the turbo spec and your motor as there are sooo many combinations
Ha ha ha,
I just went through all these issues fitting my gt30 on an rb25det. I also went the low mount and it took me 3 hard days to get the thing setup. I still have to do the injectors and get a tune done, but from the little run I had just then it should pull way harder than the stocker when tuned :D
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
