  • Replies 166
Hey guys one question.
You're using a 550hp (approx) turbo and only aiming for about 250rwkw? Won't this be running the turbo quite a bit below its' efficiency range?
If you wanted 250rwkw, wouldn't a GT-RS have been a better option due to the fact that it will be far more responsive?
A 550hp turbo should be good for towards 300rwkw.
Yeah, I am aiming for 290 to 300rwkw, shouldn't be a problem.
hey guys so happy, i started my car today, it kicked over after a small tune of Power FC, just put in a small tune to get it started and drive it to the exhaust place so that the dump can be made up, once that is done i should have my car 2 days later, the tuner will need two days, for a cold start...
im so excited i cant wait!!!!!
Keep us informed - love to see a dyno sheet!
Cheers - take it easy until you get use to it!
yeh i know everyone is telling me be careful bla bla, but hey im not stupid... i dont wanna reck wat took a lot of blood sweat and tears to build, Arup dont worry ull be seeing it soon, ill let ya drive it so u can want it, LOL...
You're letting someone else drive your car?!?!? You're crazy! :)
Just kidding...look forward to seeing those results.
On a more serious note, I know you low mounted your turbo mass_iv, but for the rest of the guys who are doing this upgrade, did you also low mount the turbo? I had originally planned on using a low mount manifold, but have also seen some nice high mount set ups and I'm curious if there's any particular benefit to doing either...
i would go for the high mount if i was going to do this again, as it would have been heaps easier. the only reason i didnt high mount it was because i was using an internally gated turbo, also the cost's of a new manifold were a little too much for me at the moment.
ECR033, did u find someone to do the work for you? if ur looking at somewhere pm me and i can give my mates at MRT a call and get a quote for you, just tell me wat work needs to be done and wat parts u have.....
Low mount is more EPA friendly and the install is cheaper.
lol
dammit!!!!!!!!!!!!!!!
u better watch out, when ur not looking your gt30 may go missing, replaced with a stock turbo :)
Hey mate I'm not sure if anyone mentioned a clutch upgrade.
My clutch was getting a little weak when I sent my car away to be "modded to the sh!thouse".
What this meant was that when I picked it up, the damn thing would just slip and I didn't get to see what the 240rwkw actually felt like. It was a big downer and 2 hours later before I even made it home it had died completely and I had to get the car towed.
A week later I got it back, although my stepdad picked it up for me cause I was at work so he got the first ride.
Funny thing was, he told my mum that he thought it felt no faster than before but not to tell me he said that (she told me anyway :)). I'm doubting he even hit full boost. Anyone should be able to differentiate between 140rwkw and 240rwkw. And I sure as hell could tell the difference.
yeh i know bout that mate, i just recently changed my clutch, ive got a heavy duty exedy clutch, although my mechanic thinks it wont last more then a month, but it should handle it for a while, ill prob go for a puk clutch or a brassy, i used to have one in there but didnt think id need it...
by the way that would suk if i wasnt the first to drive my just moded line...LOL
this has got me thinking guys, anyone know of a good clutch to handle about 250rwkw, i currently have an exedy heavy duty sports clutch, but i dunno if its trong enough, my mate has a wrx 2.5L pushing about 320awkw, and has the same clutch as me, but he rekons its only going to last him 2 weeks, as he is only using it to run his engine in...
im not sure if mine will handle 250rwkw, but i dont really wanna go for a puk or brass button clutch... any thoughts?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
