  • Replies 166
yeh i was thinking that too, but the car hasnt done many km's, so i hope its not that, ive treated it good, and its only done 70,000km..... what would be a good diff upgrade?
what exact model of tyres do u have?
if it spins third trust me mass, they cant be good :P
i got some new toyo t1rs, and although i dont have much power they are like night and day compared to my old tyres.
you dont really believe the odo do you :)
well i dunno, but my car is pretty clean Arup, and drives fine, id say it has around the 70,000km on the clock, by looking at the interior and the wear and tear its not bad, so i dunno how many k's but id believe it.... i am due for some new tyres, but its not just that guys, it spins them easy which is wat im trying to say, before the work was done i couldnt even chirp 3rd, i even struggled to spin 2nd with these tyres....
yeah your car is a very clean one, one of the best ive seen, i see what u mean, lots of extra power compared to before :) cant be bad!
i guess when u get your car back you will have plenty of fun frying your current tyres before u get some new ones :P
lol, i will indeed, just have to be carefull not to fry other things!!!!!
thanks for the comments, i think mine is a clean example... i have to take u for a spin soon Arup. Pete, you and i have to go for a cruise soon..
Is the condition known? The $600 1/1.5/2way second hand items have an unknown condition/possible rebuild.
$800-$900 second hand are generally a good second hand item.
Thats what I've came across anyhow. Obviously there are some good deals floating around, just need to be in the right place at the right time. :)
Edited by Cubes
yeh i dunno man, mine seems fine for now, it was just a thought, cant really spend that money on a good working diff atm...
was thinking of working my gear box a little....
yeah i doubt the diff would be that much of a problem. best to save money for other stuff that might break.
either way, cubes, for you info you can get 1.5 or 2way kaaz lsds brand new to your door for $1150 with 2 bottles of oil, so i think 8-900 for a second hand is a bit on the dearer side :)
http://www.nissansilvia.com/forums/index.p...c=76985&hl=diff
tuner just rang me and said he found 2 cracvked plugs while tuning today, had to replace them..... i have to say skylines are a hastle some times, he had to take the piping off 3 times LOL...
i cant wait till saturday.....
I've had issues with cracked plugs, that was such a nightmare. I had the plugs out 2 times and couldn't see any cracks, the third I found one plug with a crack, the tuner found another 1.
Need to be very very carefull tightening the suckers up. Keep it 90degree's, I was lazy and left the cross over pipe on and used a swivel. :)
yeh i know he was telling me, he took them out the first time to gap them, then had issues later so he checked them out to find one cracked, then again checked them to find another one cracked.
hey guys, my car is finally back..... overall im happy, although there are a few more things needed...
the car is a little laggy, hits full boost at close to 4000rpm, which is the bad part from all this, but i have to say its a lot stronger....
the car pulled over 240rwkw...
which i think isnt too bad, with the standard engine and cams...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
