16,482 Rockinghorsepower ATW.
Dude, power will be different for every engine.
You dont even state what other modifications you have. Even if you only have an EBC and a few pounds more boost, and a decent exhaust and intake, you'll make vastly different power to a stock car. Also, the amout of power GAIN will vary depending on what mods you have, and then theres the fact that HKS make I don't know how many camshaft variants.
Sorry to shoot you down, but get real mate or post more info if you want real answers
https://www.sau.com.au/forums/topic/84424-r32-gtr/#findComment-1527973
SEARCH BUTTON PLEASE
I cant stress this enough. You want fast answers its the fastest way.
You wont be able to make your of CAMS with a stock ECU.
What other mods do you have?
What dyno are you going to use (this will have an effect)
Do you realise dynos are a tuning tool? As long as its tuned well the number doesnt really matter.
https://www.sau.com.au/forums/topic/84424-r32-gtr/#findComment-1529716
lol.. have you tried *using* the search yourself recently?? try gtr cams into the search ash and see what happens..
http://www.skylinesaustralia.com/forums/in...topic=53802&hl=
there is fresh stuff, although Poncams are not HKS items in that threads case.
I mean the original post doesnt even have what Spec the cams are
There isnt gonna be a 11ty billion KW difference however.
The search button is a pain at the moment. But you can work around it
https://www.sau.com.au/forums/topic/84424-r32-gtr/#findComment-1529939
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
