Hi there all,
Need to ask a favour.... I'm getting married the first week of December this year and I need another another 3 or 4 GTR's(preferably 32's at this stage) to accompany my gtr to use as the wedding cars.
The 2nd is a Friday so people may need to take a day of work.....happy to pay(PM me so we can further discuss)
BTW the photo's will be taken at the (hopefully)War Memorial, National Museum and possibly the Parly house's) and I'm going to try and get the photographer to take some photo's of the cars too....
Richard,
Will your beast be back on the road by then?
and can someone PM me Goran's number (I had it, but lost it in a new phone incident :( )
Cheers,
Brad
https://www.sau.com.au/forums/topic/84431-wedding-request/
  • Replies 56
Posted Images
grrr i cant find his number, stupid changing phones and losing numbers!
If you also wantr a convoy of skylines im sure plenty of the boys will be happy to really make your day something special, I dont plan to have mine by then but if i do i'll be happy to come along for numbers.....15 skylines sure do have presence!
https://www.sau.com.au/forums/topic/84431-wedding-request/#findComment-1528025
I now have Goog's contact details(Thanks Geordie)
and also the use of Geordies GTR..
That's 2 GTRs(Geordies and mine), 3 with Googs(*crosses fingers*....)
anybody know the state of Richards beast?
Mmmmm convoy of Skylines, would make some good photos(the wedding photos would be good too *grins*),
will have to run it past the boss....
https://www.sau.com.au/forums/topic/84431-wedding-request/#findComment-1528401
someone tell me if i am wrong but i dont think it has had anything done to it in the last few months. i doubt it would be ready by when you would need it but we are all hoping the sin is back on the road soon.
https://www.sau.com.au/forums/topic/84431-wedding-request/#findComment-1528507
she's right - dust is still on it.
That a man shame Richard... as said before please let us know if you need anything.
On a brighter note many thanks to Nik for the services of his GTR for our wedding! It's muchly appreciated....
Just gotta get around to ringin' Googs.....
https://www.sau.com.au/forums/topic/84431-wedding-request/#findComment-1530147
  • 1 month later...
She's looking good Phil.
How's she runnin'? Looks like I'll be up for a rebuild next year, changed the plugs on the weekend and number 5 and 6 were oiled up.... gotta devide whether to take her to Trojan or to ProEngines
Where for art thou Geordie?
https://www.sau.com.au/forums/topic/84431-wedding-request/#findComment-1624879
Proengines are awesome! Had my motor done there 2 years ago, shes clocked up 30,000kms since and only had one small problem (which Greg happily fixed at his expense). They definately do awesome work :)
https://www.sau.com.au/forums/topic/84431-wedding-request/#findComment-1625185
From what i hear about proengines i would say to get them to do it aswell as Trojan. Either way, You'll get a great job.
My Engine is fantastic, So smooth...
You'll see soon!!! :D
https://www.sau.com.au/forums/topic/84431-wedding-request/#findComment-1628095
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
