hey all im going around trying to find a good exhaust to put on my Series 2 R33 and im coming accross heaps of different prices and wondering whats the damn diff??
Australias Best Tyre and Muffler - $1500 3 inch turbo back
Hi tech mufflers - $1875 full stainless steel system.
Then ive gone to auto barn and trust cat back 80mm item for $880.
Is there a big difference between turbo back andd cat back?? Can I get a cat back then later on turn it into a turbo back system? Just trying to justify the price difference. Im your opinion what is a decent price on a exhaust system? Do you think the above prices are a complete rort???
https://www.sau.com.au/forums/topic/84457-exhausts/
Firstly there is a fairly big difference between turbo back and cat back systems. Turbo back should make a noticeable difference to power over a cat back because there is as much, if not more restriction befoe the cat as there is after it. The stock dump is maybe the biggest restricion of all! Also the compliance cat is pretty bad too. Here is my suggestion Batmbl on this forum sells very good front/dump pipes a mild steel split dump/ front pipe is $395 then a highflow cat can be around the $190 mark (or around $100 for a second hand original GTR, not compliance,cat) then maybe a second hand cat back can be had for as low as $300 on the for sale section of this forum (mine was :() So all up we are looking at around $900 for a turbo back exhaust! Also on Ebay there are turbo back systems for around $700 not sure how good they are but..
Also in answer to the second part of your question all of these parts can be fitted at different times so it is possible to turn a cat back into a turbo back..I have been researching this a fair bit so any other questions feel free to pm me!
https://www.sau.com.au/forums/topic/84457-exhausts/#findComment-1528085
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
