i have installed a Auto Meter Air Fuel Ratio gauge in my R33 yesterday, all i need to do is connect the signal wire. Does any know which wire to connect this to?
hook it up to the oxy sensor middle wire on the harness connecting plug , black wire , well thats what i did on my r33 rb25de harness and it works . or alternatively hook it up to pinout 29 on your ecu
NICE! i too have my gauge in but havent connected the signal wire. ive posted and no one has NFI about which pin it is on the ECU for a RB20DET.
If worse comes to worse ill just splice it off the o2 sensor wire in inbetween the 02 sensor and ECU, but the pin would be prefrered.
Hey Guys
I need to know this and will post up the details if my contact pulls through tomorrow.
I am installing a Autometer Air/Fuel Ratio Gauge into a Series 1 R33 GTST
Will keep an eye on this topic, but will inform you if I find out myself.
Doing the install Saturday
Cheers, Chris
Are the RB20DET and RB25DET ECU pinouts the same ? Where can I get the pinouts for the RB20DET ECU ???? I need to connect my AFR guage and Fuel Computer and don't want to splice in the engine bay.
Cheers,
ok, connected it up to pinout 29. works, however, only on one side of the gauge. does anybody know what the voltage range is on the stock oxygen sensor? because i was getting a negative voltage at one stage using my multimeter. and i know that the Auto Meter gauges are designed for 0 - 1 volt. has anyone installed one of these and it is working correctly?
can i just say why bother? the reading you get from these things is next to useless. seems like a waste of time, money and dash space for what is essentially pretty, sparkly LEDs.
no you can't just say that. if you've got nothing constructive to add to the thread, don't post.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
