tried to post results before but it didnt take. anyway i just had my rb25 rebuilt with gtr rods and wiseco forged pistons due to my engine trying to swallow a shoddy weld done to my new induction tract to my new gt 30 500hp internal wastegated turbo. i decided to throw in some step one tomei poncams 256 degrees duration 8.5mm lift and i thought id share my results with the forum. power went from 260rwkws at 20 psi to 277 rwkws at 21 psi! im really happy with the result. probably only do minor tweaks to the engine now like greddy plenum and 4inch magic cat, cant wait to take her to the track!! id love to hear from anyone else running this turbo? the specs are gt30 500hp internal wastegated with a/r 70 comp cover and a/r .63 exhaust. i bought the turbo from horsepowerin a box.com.au
https://www.sau.com.au/forums/topic/84471-i-gained-17-rwkws-with-tomei-poncams/
Going back 12 months ago very few people upgraded cams, but now a lot of people that are making mid 200rwkw are starting to realise how much extra power can be had from changing them.
It doesn't seem to be a massive power gain (especially with a boost increase) in comparison to some others I've seen, but I can only assume the you would have set them for better boost response and mid range power rather than top end?
Are you breaking traction in 3rd gear under acceleration yet?
Congrats on a succesful upgrade ;)
I have 277rwhp at charlies motors in brisbane which is tested with out any componsaters on the dyno, and i break traction in 3rd, you should be getting wobbly in 4th by now.
I'm just talking about putting your foot down in 3rd and when it hits boost, the car steps sideways. If your car is doing this with 255 on the rears in a R33, then you must be making some serious torque.
That comes more down to suspension and tyres. R31Nismoid and myself have the same cars.
I have 265 yoko rear rubber and 235rwkw and break traction in third as it ramps up to boost.
He has generic rubber, 235 I think and his old engine made ~300rwkw and didnt blink in third.
Obviously his suspension and alignment settings are more sorted than mine.
330rwkw :P and it only slightly started to move in 3rd as it ramped onto 24psi @ 4200-4500
running 225/16's :P Just keep the right foot into it and it would come good after the slight move
@ 270rwkw it didnt move by any means, very great to drive once it was on boost. Very quick streeter.
As for power Bigcarl, awesome man. The cams help indeed.
The power can be made without them, but they will give you some increase (what i setout to do. ie no cams)
I think you'd be on the limit now of the turbo @ 21psi. Only due to that .63 rear end.
If it was a .82 then you'd be closer to 300 even @ the same boost IMO
I take it 21psi is the limit as its starting to detonate at anything more?
got a dyno sheet now? Hopefully looking a lot better than your previous one
Very nice. :D
The .7 comp cover over the stock gcg style setup definitely proves worth while. Slap a VG30/R34 hotside on it and you 'may' see 299.99999rwkw.. Wouldn't that be a bugger. :cheers: So close to the magical 300rwkw mark. :D
How does it hold boost up around peak power?
Does it tend to tail off? What EBC are you running?
I know of RB25DET with cams making slightly over 300rwkw, Tim Possingham the prior owner of Horsepowerinabox used a VLT turbine housing, unsure of the chra or comp cover, I assume he had it powerported or similiar as the turbo's cost was up at 3k.
Works well though, I remember Freebaggin telling me at 17psi it was somewhere up around 280rwkw and would ramp on hard at around 3500rpm.
Edited by Cubes
Carl well done buddy!
I just placed an order for a set of these cams, 2 days ago :cheers:. In two weeks car goes in for cams, head porting, VG30 ext. upgrade on hi-flow RB25 turbo and tunning.
Really would like to read (and see via dyno sheet :D ) how the cams effected drivability. I am hoping they wil give me more low/mid range power and torque, also that they allow the turbo to boost up quicker.
Is it worth getting adjustable cam gears with Tomei cams?
hi Al, nah you shouldn't need adj cam gears for the poncams... they have been specifically designed for the RB25 vct and work nicely straight out of the box... however if money is no concern and you would like to play around with the timing, let me know the results!
i havent picked the car up yet, just spoke to tuner. i will ley you know how it drives when i ve had a good drive. the cams were set on o in stock position no adjustable cam gears. my engine tuner seems to think that an aftermarket plenum would make a difference because less twists and turns e.t.c but for $1200 i dont think id bother. he reckons if i fit a larger exhaust housing like you guys have mentioned that would probably nudge peak power closer to the magical 300 rwkw mark but for now im really pleased with the result. apparently there was no more power to be made over 21psi, i think detonation was definately rearing its ugly head at anything over 21 psi, with the restrictive .63 a/r exhaust housing. also i think the boost spikes o 22psi or so that was the only way we could hold 21psi through out the whole rev range . i will post up shoot out graph as soon as i pick my car up. im running link ecu and electronic boost control.
I see that Nengun list two different part numbers for the 256 Poncams on the RB25 in the R33, series one and series 2.
Out of interest which part number did you order and is yours a series 1 or series 2 and can anybody tell me what the cam differences are so I don't end up ordering the wrong ones :D
I didn't go through Nengun this time as there is a Melbourne supplier that imports these parts and was only $60 more expensive. Using Nengun you run a gamble with customs charging tax, as with RMS Motor Parts the price is final.
Part Discription:
Tomei - Pon Cam Shafts
ECR33 Series 1 (RB25DET) - Duration: IN,EX 256 Lift: IN,EX 8.5mm Code: 143020
RMS Motor Parts
Unit 3, 662 Whitehorse Road,
Mitcham, VIC 3132
Phone: 03 9872 6669
Fax: 03 9872 6697
Website: www.rmsmotorparts.net
took her for a drive last night, bloody quick now. tried standing start , launched her at 3500rpm. wheelspin city, span all the way through 1st 2nd and 3rd gear. my dunlop lemans 245x40x18 were useless!!! now i can see why people buy gtrs, cant get traction!!! how am i going to go at the drags when i cant even launch it at a mesely 3500rpm???
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
