I'd say Derek Oats (last year's winner) will probaly run his R33 GTSt, same for Andrew Blakney with his R33 GTR.
I also hear Bart Dove (has run in Karts and Forumla Vees) might be running a Skyline he's got too.
I plan on running the GTR, if I've got some front brakes intime... 26Motorsport now has my Brembos on his R32 GTSt track car.
Anyone else running Skylines?
https://www.sau.com.au/forums/topic/84478-domain-hillclimb-18-sept/
  • Replies 48
Barts selling his car isn't he?
Well if i can get my car ready in time i wouldn't mind giving it a run and having a go. :)
Cheers B
all the needs is a 1kg fire exh and a secondary bonnet latch (chain or even just a leather belt). give me a shout if you want a hand.
Yeah cheers man.
I need to get my FMIC and oil cooler on as well and get the car tuned, so i'll see how i go for time and if i can find a hoist to borrow :P
what did you get bart?
hey guys, its bart dove here. im aiming to go in it, just trying to get my car ready for it, hopefully all will be well.  should be a good day if the weather holds up!
I got a 1990 GTS-t, just completing the usual mods, filter, full zaust, upping boost a little.
havent used it in competition yet, so will be a good learning curve.
just dont think the suspension will be suited, it has ultra-hard TEIN drift coilovers, i'll probably bounce down a bank somewhere, hehe.
    • Don't think that can fit in physically. Are you referring to this?    If it happens again, I'm going to get the nismo ones.
    • I bought the 1/18 scale celica and nsx from Justin and they are very detailed and good quality. I will definitely be interested in others in the series as they come out
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
