Yeah mine doesnt fit my r32 gtst either. Apparantly the easiest thing to do is to get a really cheap one that fits from Auotbarn etc and take the nylon/plastic insert out from the middle and fit it to the Nismo gear knob.
But i dont know how ur meant to get the plastic out, its stuck in pretty hard, maybe even glued.
i got a nismo gear knob :rolleyes: it came with the car and it looks like it fits the gear stick like they were made for each other. does that mean i have a different gear stick or what?
nOOSE
is it one like this?, I got it in the recent grop buy
The gearknobs come with 15mm inserts unfortunately :)
There is a screw in the top and you just unscrew and get a 10mm insert. Alot of people glue them in but im not too keen on that idea.
Greg
hmm, I don't wanna just go out and buy a random knob and try it multiple times and have all these useless knobs sitting around :)
anyone solved the problem with a 10mm insert yet?, which gear knob did you buy?
Yeah n00se we have pretty similar GTR's....your s has white rims and a boot lip and mine doesn't tho.....and I have the black chrome gear knob too :)
cheers
Tom
I went into Autobarn the other day and they sell the inserts by themselves, so you dont have to buy a gearknob.
But since i still cant get the plastic out of the centre of mine i couldnt try any to see if they fit. :-(
thanks mate....
Ah no i didnt buy one, i couldnt get the centre out of my gearknob so i couldnt try a new insert.
I went to Autobarn in Brighton Vic, they had heaps of inserts under the counter.
I originally asked for the cheapest knob they had but i got talking with the sales guy and he had an R33 and new what i was talking about.
Hes not on the forums though, how could you have a skylinein Aus and not be on www.skylinesaustralia.com ? Its a great way to waste a fair chunk of your life.
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
