hi guys im upgrading my 33 at the moment and im puting on a garret gt35r turbo and i was wondring if any one knows much about these turbos do they have mumch lage they told me its rated at 600 hp is this true i am hopeing to get around 300rwkw with apexi power fc big front mount 500 hp fule pump and fored pistons but he told me my stock injectors whould be able to handle it but if i put 555cc injectors on it what power am i looking at any help whold be greatful
p.s heres a pics of my car.
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/
Mate ill give you the best advice you'll find on this forum
search
this has been covered 100's of times.
GT30, 500-600hp is the way to go.
Search and hav e a read of all the threads and thier comments and then post if you have any further questions (which i doubt you will)
I've gone into depth as have many other's using the GT30.
GT35 is too big for a true fast streeter
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1529394
Your 33 is just a normal gtst isnt it? It looks like a s2 with some wild body kit and massively pumped guards. If it is a 25 then you will need the injectors for the power...the turbo will make it easy. Std internal limit is about 400rwhp. but i dont think anyone recommends going over 250-260 rwkws, So i would think pistons are a definete, maybe rods also. I know camshafts will help reduce the massive lag you will have with the turbo. If your only chasing the 300 rwkws a smaller turbo will do the trick and you wont lose out on so much response, unless your only after the high power and top end approach.
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1529418
I think a lot more people are recently posting these questions about the GT30 and 35 units because they are at such a good price. Maybe it would be worthwhile making one such thread that covers both these turbos sticky.
I think R31Nismoid is on the money suggesting the GT3040 unit. I think the .82 housing is the way to go for your set up. But if you don’t mind a bit of lag the GT35R is not so bad either. On an old post on this forum someone stated that a GT3040R with 1.06 housing performs the same at the GT35R with the .82 housing. Maybe do a search and have a read as there is a wealth of info on here.
Turbo specs: GT3040R comes in .63, .82, 1.06 housings and is rated between 500-600hp
GT35R also comes in .63, .82, 1.06 housings and is rated between 600-700hp
And dude, that is one wide body skyline!
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1534744
GT35/40r .82, 1.06 Is 700hp .63 is 600hp
GT 35/40r 700hp roller bearing turbos for $1799 BRAND NEW in the box with 12 months warrenty.
For ur skyline .82 would be fine 700hp 1
where could i pick one up for 1799?
got a link?
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1535247
GARRETT GT35/40 BRAND NEW x 3 - $1500 XR6Turbos
http://www.calaisturbo.com.au/showthread.php?t=50543
$1799 BRAND NEW garret 35/40r
http://www.calaisturbo.com.au/showthread.php?t=44231
not sureif u have to sign up, its a VLT website tey got so much stuff for sale
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1536582
got a link?
Lets support our sponsors/donators contact Tarek from RACESPEC; details below.
Mob: +61 401 313 163
Fax: +61 8 8359 7953
Web: www.racespec.com.au
[email protected]
RACESPEC do these units for $1775 delivered.
https://www.sau.com.au/forums/topic/84516-gt35r-turbo/#findComment-1536686
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
