EIDS:
Brisbane:
Near new:
Took BOV off so now not needed:
Pick up or can post:
[email protected]:
HKS Electronic Idle Stabilizer EIDS TYPE-H1
$99 posted or picked up
Cost $250 from BD4's comes with original recipt. In original Box with english instructions. Also has harnes.
The HKS EIDS buffers dramatic airflow meter signal fluctuations. By buffering these fluctuations the EIDS prevents engine stalling or stumbling associated with sudden imbalances in air/fuel ratio of airflow meter-equipped vehicles that utilize atmosphere venting blow-off valves.
Edited by emanuelt
