Hey everyone,
Unlike the majority of guys and girls here, I am not 100% with all the bits and pieces on the Skyline, and am quite adamant to do any servicing or maintenance myself (oils, sparkies, o2 sensors etc.)
Usually for this type of dilemma I'd just consult a workshop and pay some guy to do it all... but I have read that people tend to rip you because you own a performance machine.
As such, I am seeking anyone who is confident with their Skylines (particularly R34s and RB25DETs) to help with some of the small things - paid for of course.
I'm seeking Northern Beaches people due to proximity to home but if anyone is genuine about it, I don't mind driving :cheers:
Thanks all! I know a lot of you may think its strange or whatever, but seriously - just not too confident with my knowledge of the car ~
https://www.sau.com.au/forums/topic/84550-northern-beaches-oppurtunities/
  • Replies 127
Posted Images
Thanks all... at the moment just an oil change, new oil filter and change the sparkies to Iridiums. Possibly do the o2 sensor (Ford EL unit as well).
I have most of the gear ready.... just need a time and place (Sunday is most preferable since I work all 6 other days)
Can you guys just post up how much I'm looking at for something like that from one of you?
Cheers for the support ^^
Can I come and watch? Is there lots of parking at your house?
Im free Sunday too and would love to learn! :P
Dudes...
Beer and ample company or "spectators" are most certainly welcome... I will provide the beer (please put preferences).
As for the space where we're going to do it... Unless you like to work on cars at a 45 degree angle, my house is not good at all.
1 extra case of beer to the person who donates house as well :P
Also, I'm going to go buy the Motor Oil and o2 Sensor this weekend...
Any suggestions on which oil to use (Motul is the favourite on SAU) and where to get it from for cheap? If your answer is going to be Motul, please give me the number as well as there are a few available.
o2 sensor fron NTK or ACA... which one is better? And again, where should I buy it from?
Thanks
Compared to Motul is that better? I have heard several SAU members use that ELF.
Please work out a price for me then ;) Where is Powerplay Imports - obviously I'd need to pick it up from you~
It's great oil as it's 100% Synthetic and very reasonably priced.
Elf claim that it is a better quality oil to the Motul 300V and that it doesn't break down as easily asthe Motul does
We're on 82 Victoria Rd Drummoyne. Come over the Harbour Bridge, then the Anzac Bridge and up Victoria Rd. We're on the right hand side after the Iron Cove Bridge with 2 R34's parked out the front so you wont miss us.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
