Hi Guys,
does anyone have a good condition (unbent, unchewed etc.) plastic Fan from an R33 GTST?
i am just looking for the plastic part of the fan (the fins), not the fan clutch etc..
i am in sydney, but will pay postage (as long as the fan isn't too $$)
https://www.sau.com.au/forums/topic/84560-wtb-r33-engine-fan/
