Tommyk - PM sent.
blk180 - Thnx for letting me know. I'll keep you posted.
liber8_d - PM sent.
Drift King - Thnx for letting me know. I'll keep you posted.
  • Replies 106
Paul - is it still possible to get in on this for a PowerFC? I have a 1996 R33 GTS-T Series 2.
EDIT - Btw I should add that I am able to make payment immediately if I can get in on this buy. ;)
Edited by Ionos
There is one (R32/R33 GTR) here for immediate delivery. (sorry for the hi-jack) we need a pro and will buy one through you when we sell this one.
http://www.skylinesaustralia.com/forums/in...st=0&p=1533076&
Hi
How can u tell if it's a PRO fc and a standard fc ?
cheers
Hi
cheers
The Power FC Pro Spec has been designed for drag racing use. These units have additional functions over the standard version.
*Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high powered cars. The Power FC Pro Spec.CPUs cut ignition at the rpm limit to prevent the
*knocking that could potentially destroy the engine.
0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
Also the serial numbers :P
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
