Hi all,
Looking for some advice from those in the know as to what to do about valves when having an RB26 head serviced. Is it wise to replace them with new standard or aftermarket items? or can the existing valves be safely re-used?
The head is having Tomei valve springs and bronze valve guides fitted so it seems logical to me to replace the valves also - I may be wrong
If aftermarket valves are the go, which are the best to look for?
Nick
Guest DIRTgarage
Hi all,
Nick
Nick, the valves will probably only need to be reseated...the stems should be fine if using new guides. The stem seals will need doing too, especially on the exhaust side.
Thanks Paul :P
Is it best to purchase new genuine valve stem seals?
Hi Nick,
Normally if you buy a full n1 gasket kit ,it will have valve stem seal in it, are you doing a full engine rebuild or just the head? So your fitting some tomei valve springs does this mean your putting sum nice lumpy cams in? If you are, and if they are over the poncam sort of lift 9.15mm i would invest in some new tomei cap retaining studs ,not very $$ and good insurance (as has seen studs fail on a high lift cam setup). best of luck with the mods.
pete
Guest DIRTgarage
I wouldnt want to let the cat out of the bag now pete :P
Pm me
Matching your camshaft profile with your turbo selection is critical on these engines. Make sure they are both producing the power where you need/want it. If you want pm me for more info.
Nothing new on that front Paul, Poncam 260's with 9.15mm lift - So cap cam studs may not be needed
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
