Hi all,
Looking for some advice from those in the know as to what to do about valves when having an RB26 head serviced. Is it wise to replace them with new standard or aftermarket items? or can the existing valves be safely re-used?
The head is having Tomei valve springs and bronze valve guides fitted so it seems logical to me to replace the valves also - I may be wrong
If aftermarket valves are the go, which are the best to look for?
Nick
Guest DIRTgarage
Hi all,
Nick
Nick, the valves will probably only need to be reseated...the stems should be fine if using new guides. The stem seals will need doing too, especially on the exhaust side.
Thanks Paul :P
Is it best to purchase new genuine valve stem seals?
Hi Nick,
Normally if you buy a full n1 gasket kit ,it will have valve stem seal in it, are you doing a full engine rebuild or just the head? So your fitting some tomei valve springs does this mean your putting sum nice lumpy cams in? If you are, and if they are over the poncam sort of lift 9.15mm i would invest in some new tomei cap retaining studs ,not very $$ and good insurance (as has seen studs fail on a high lift cam setup). best of luck with the mods.
pete
Guest DIRTgarage
I wouldnt want to let the cat out of the bag now pete :P
Pm me
Matching your camshaft profile with your turbo selection is critical on these engines. Make sure they are both producing the power where you need/want it. If you want pm me for more info.
Nothing new on that front Paul, Poncam 260's with 9.15mm lift - So cap cam studs may not be needed
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
    • Ok now I’m extremely jealous
