  • Replies 148
Well you gotta admit a guy wearing a red carnation at motorvation is an easy target and if i wasn't gunna get ya I'm sure some of the Trevs would have :lol: j/k
Car is getting some work done at the moment... Had troubles installing Apex ITC as problems with wires were found... My fingers are crossed as I'm going on the dyno run for something to do! Not expecting big figures at all just havin fun thats all.... hoping to pull nice figures for cabin auto salon though if i get asked to put ole sly 33 in that..... I'm savin up for a Macka special kit :lol:
https://www.sau.com.au/forums/topic/8459-motorvation/page/8/#findComment-128720
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
