Hey guys,
I want to get my Stag down into the 13's or just a 14 flat would do probably. I have a mate who has a Series 5 RX7 Non Turbo with mild porting and some extractors. Now it pulls a very low 14. And I'm sick of him beating me. What do I have to do or get (without spending big bucks) to get my Stag into the 13s? She is currently stock as a rock series 1.
Cheers,
CSV ;)
https://www.sau.com.au/forums/topic/84618-getting-the-stag-into-the-13s/
According to the 1/4 Mile calculator you will need 370 bhp (280 kw or 215 4wkw) to do a 12.9. That's simple;
SAFC or DFA $70
IEBC $70
SITC (if you can find one) $210
Ball Bearing hi flow of the standard turbo $1800
Split dump $500
3.25" exhaust with hi flow cat $500
Adj exhaust camshaft pulley (for average power, not max power) $170
Standard injectors (maybe with an adj FPR & slightly higher fuel pressure) $180
GTR fuel pump (standard wiring OK) $150
R32GTR intercooler (or equivalent). $400 + $450 for pipework
Auto transcooler $150
Auto valve body upgrade $300
Any decent tyres will do (it's a 4wd auto after all)
Careful tuning $200
Total around $5K
Hang on !!!!! That sounds almost like our Stagea.
:P Cheers :blink:
Edited by Sydneykid
  CSV Imports said:
Thanks soo much sk. How much would all that set me back? :rolleyes:
I stuck my guess at the prices in the previous post above. That's doing the fitting labour your self and building the DFA and IEBC.
:unsure: cheers :huh:
thanks sk! :rolleyes:
Just a few more questions. Eventually (around 5 or less yrs) I want to try and have my Stag running 11's in full street form. Now, what sought of gear and what sought of money am I up for to achieve this?
Edited by CSV Imports
There is big difference between 11.9 and 11.0, so let's try the middle
11.5 needs ~600 bhp (360 4wkw)
That's about $40K worth, including gearbox and drive line upgrades because I reckon it's gunna break the Stagea stuff with 600 bhp and 1800 kgs to pull. Almost everything from the fan to the rear diff will need to be upgraded.
  CSV Imports said:
Ok, so what sought of turbo should I be using?
That's an excessively simplistic question, the answer is, it depends on what engine configuration. Do you upgrade the RB25, or swap in an RB26, or go for an RB30? Twin turbos or single? Manual or auto? There are many ways to get a Stagea into the 11's, just pick one.
:rolleyes: cheers :unsure:
One big help in 1/4 times will be a manual as well to give a good launch :)
But to keep the auto (more cost effective) sk has noted the most needed upgrades, if you could get a torque convertor to up the revs though would help a bit as well, but then forget about city driving :)
Yeah, I will be changing to a Manual gearbox in the near future, all I need to do is find out roughly how much it will cost and where I can get it done. Would the manual gearbox greatly improve the Stagea's 0-100km times and 400m times even if the car apart from the gearbox were standard? :(
sk - (or anyone else who knows the answer) I can get these parts quite easily (mates car) -
R34 GTT Side IC
R34 GTT turbo and a
GTR fuel pump.
I will also be purchasing a -
Auto transcooler
SAFC or DFA
IEBC
What sought of power and 400m times will I get with these?
  StageZilla said:
on the same topic, whats a stagea weighing 1800kg and 600hp at the rear wheels capable of with suitable gearbox etc? :D
thats manual, 5 speed, and rb26 with 2.7L jun stroker kit, and 4.3 diff gears :P
BTW dude, are you planning on any exterior mods?
1. R34 GTT Side IC
2. R34 GTT turbo and a
3. GTR fuel pump.
I will alse be purchasing a -
4. 3.25" exhaust with hi flow cat
5. Auto transcooler
6. Auto valve body upgrade
7. SAFC or DFA
8. IEBC
Suggestion follow;
1. Around 200 4wkw seems to be the max from them
2. Around 190 rwkw (ie; not much more than the non neo RB25DET turbo)
3. Around 265 rwkw at 12 volts. bit over 300 rwkw at 13.8 volts
4. Around 400 awkw if it is a good one
5. No difference to power, but essential for durability
6. Slight improvement in 1/4 times
7. Should do 200 awkw easily
8. Good for response and average power.
The weakest link is 190 4wkw. so that would be around mid 13's.
;) cheers :D
  StageZilla said:
on the same topic, whats a stagea weighing 1800kg and 600hp at the rear wheels capable of with suitable gearbox etc? ;)
thats manual, 5 speed, and rb26 with 2.7L jun stroker kit, and 4.3 diff gears :D
Should just sneak into the 10's. :) cheers ;)
