Hey guys desperatly seeking the front and rear bars and would like to inspect before buying.
And no im not getting them from Jetspeed. <_<
Also does any1 know if the front bar(made for series 2) will fit up2 a series one R33?
Cheers
Cheers
damn that kit looks hot. not too over the top, just how i like it! looks factory
Jar, I noticed you post the exact same reply in his other thread. Just let him do what he wants, it too doesnt make sense to me but isnt my car. Seems as though he wants an aftermarket/modified series 2 to fit on his car. Personally, I wouldnt buy that kit as a it being aftermarket its easily going to cost xxxx amount while a stock series 2 bar would be considerably cheaper.
it isnt factory.
also.... why do you want a series 2 bar put on a series one :S, it still makes no sense to me why you would swap a stock bar for a stock bar, see my pic <<< stock bar
i know its not factory...
when someone says something like that "it looks factory" when referring to an aftermarket mod, it means it suits perfectly, and looks like it could've come that way out of the showroom :P
yeah i know, im not saying he shouldnt, i jst dont see what sense it makes is all :D
btw, thats a nice pic in ur sig. :)
when someone says something like that "it looks factory" when referring to an aftermarket mod,  it means it suits perfectly, and looks like it could've come that way out of the showroom :D
:lol: ohhhhhhhhhhhhhhhhhh i get it, **JaR** and 2 hours of sleep last night and red bulls this mornin equals.... :)
Reading comprehension is strong in this one.
A front bar made for series 2, such as the one in the photo.
He didnt say a stock series 2 front bar
Have a look guys its not stock, plus i dont have series 2 indicators so without that the gap will be bigger, plus, its only being used as a base, hopefully u can see how 'stock' it is at MAS.
so anyone know where i can find this? Im pretty sure theres at least 2 peeps from Vic that can supply this kit, if u are please own up..
Oh and can S2 bumpers fit S1?
from what i've read...not without chaning to series 2 headlights, and bonnet.
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 馃槢
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
