Hi guys...im a newbie and this is my first post so bare with me
I need to install a new system into the sky but not sure about all the Watts and Rms stuff on the amp (im hopless when it comes to car stereo)
Anyways i have a 50Wx4 amp and i wanna run 7x10s, splits, and sub....i dont think this is possible. Can you guys help with recommending me a different layout. Do i need to get another amp? or is it better to run two amps? and how do you do it.
Also what size is the standard front speakers.
Thanks
https://www.sau.com.au/forums/topic/8462-need-help-with-audio-layout/
Do you already have the 7x10s + splits, or are you still looking to purchase?
** Warning: the following text represents my opinion only :) ***
If you intend to run a subwoofer, I would recommend 6" 2way splits in the front (from memory the stock skyline front speakers are 6") and 6" 2 or 3 way components in the rear parcel shelf.
Depending on the quality of your headunit, if you were running only one subwoofer you should be able to run the four 6" speakers directly from your headunit using one amplifier to power the subwoofer.
As far as 'how you do it': the easiest way to hook it all up is to make sure that your headunit has enough RCA outputs for each of your amplifiers, you then do not have to worry with cable splitters which will only decrease the quality of sound further.
I'll cut this post short here as to not get too annoying... PM or just keep posting here if you've got any more questions, or any specific questions about what I've just rambled... or whatever... uhoh.. i'm still rambling....
6X9'S are good if you can't run subs. Rear speakers should just fill in the sound at the rear. Get a good sets of spits as this sets up the front stage.
Careful when looking at watts. Is it peak or RMS? Peak means jack. RMS is constant power.
You're better off getting a second amp to run the sub, and running the speakers of the 4ch amp. Reason is you get a better, cleaner signal from a dedicated amp than from your head unit's built in amp.
Also, don't bother with 7x10's if you're putting in a sub. Get a decent set of 6's instead.
If money is an issue, then run the fronts and sub off the amp and the rears off the headunit.
As Silver-Arrowz said, only look at RMS and not peak. To give you an idea most good headunits only put out about 20-25W RMS.
Are you gonna do the install yourself? VERY important thing in car audio is wiring, particularly when you throw an amp into the equation. Make sure you run at least 8g power and earth cable to your amp from the battery. All connections and terminals need to be done well too.
Could go on for ages. Feel free to PM for more advice.
Honestly do not bother with rear speakers just yet, unless you spend most of your time in the back seat you would want the sound stage right in front of you as much as possible.
Put your money towards a great set of splits and a decent headunit. Keep your existing amp (post details of it btw) and add a subwoofer that would compliment the amp that you have already. Bridging two channels of the amplifer to run the subwoofer would give you around 100-120RMS, so use a sub that is efficient at this input. Something like a JLW0 which operates happily at 125RMS ($172).
Run the remaining two channels of the amp to your splits and you are a happy chappy.
NB: what I wrote above is based on a small budget, but it will do very nicely.
Read up on this, especially Chapter 5:
http://www.decware.com/secrets.htm
Thanks guys for all ur replies...pretty overwhelmed that anyone even bothered since its my first time posting up a thread.
Well i took the advice and decided to buy another amp to run the sub. As for the splits i invested in a pair of good quality sneider 6" speakers and yups i did purchase the 7x10s already. The first amp that i had before is a kenwood 50Wx4 and the one i just got is a 200W 2 channel one (thats bridged i think)
Ive read a thread posted a while back and it says that 7x10s wont fit in the rear parcel...therefore i have to make another parcel tray.
Can u guys recommend an audio installer that does a good job since i want the wiring to be neat and all and where do i get the marterials to make the parcel tray and where can i get the carpet covering to match the car.
Thanks again
    • It's a fun daydream but personally just looking at OEM implementations of twincharged engines like the recent Volvo engines it makes my head hurt. So, so much complexity compared to even other GDI turbo inline 4s.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
