gr8 car. ive been lookin into gettin one just waitin for finance to settle itself out. that www.gtiroz.net website is useless as they are an owners club not an enthusiasts club and u can view bugger-all of their site.
Im budgetin to spend approx 16-18k on mine as thats what it takes for a decent one nowadays.
You can usualli find one locally for about the same price as importing one nowadays and the clutches/ brakes and maybe gearboxes are all upgraded for ya!!!
Especialli if your in the eastern states. otherwise if ur in perth/ WA forget about finding one locally.
Paul
POCKET ROCKETS..a good friend of mine has one ..done bugger all to it and got a 13.9 out of it..the clutch did get done in it this week and it was an engine out job..and the gearboxes are a bit of a let down in em..other than that sr20 turbo AWD quad throttle body standard, killer package..they have a steel compressor wheel turbo standard too so dont be scared to wind up the boost
One of my best mates owns one and I know the gearboxes are weak but ones you break something if you replace it appropriately it wont break again. He spent like 5k on a gearbox rebuild and its tough as now, will withstand some mighty power.
I love them to death and will probably get one after the r32 monster of mine lands :)
Greg
defo go see here:
http://www.gtiroz.net/
I have owned 2 gtirs in my time.
Love them to bits. Need money and need to be well well maintained.
But can be awesome cars.
keep in mind there are a few dogs around that will be very tires gearbox and motors etc....
Mick
My best mate has one... he has had it for just over a year, and it has spent at least half of that time in the workshop. He's blown the stock turbo, two heavy duty clutches, and has had some suspension issues... and the latest, bearings on the gearbox input shaft are packin it in. Its a 92 model with just under 100,000km.
He just drives it too hard, and the turbo blew coz he was running 14psi through it, which was asking for trouble!
My opinion is that if you go easy on the drivetrain, then you should have a reliable car. Theres no need to worry bout the SR20, but when its making bigger power the stock gearbox/diffs/clutch starts to get a bit tired.
Great car in many respects tho... I considered getting one for a while :P
  • 3 months later...
www.gtiroz.net good luck tryin to sign up though the mod shalom made an obstacle course..
i am an EX-owner of the pocket rocket RNN14..
great lil car. cheap as.. and the best SR20 factory engine ever. quad throttles r sweet.. prob with tunning as limited acum in plenum
when buying... get a 93-94model.(personal prefereance) nissan badge at front not P badge. basically if u blow ur gearbox or clutch its engine out. and the stock gearbox is basically a FWD box with a N/S transfer case for the rear tailshaft.. brakes are a bit undersized.. understeers alot due to being front heavy.. remove the front sway bar and get a whiteline rear sway bar... fixes it..
in a straightline ive blow away ferrari's evos STi'S GTR's. few grand on mods makes em quick. u can throw them into corners at high speeds get it sideways and come out on top. handles extremly good once u get the right suspension. very reliable apart from the gearbox but a par set will cost only AU$4000 and very worthwhile. good daily driver too. fairly spacious more than GTR. expect 350km per tank 45L.. and be aware that the thing is noisey.. timing chain solid hydo lifters.. tap tap tap.
my old GTiR had 160kwatw's (110kwatw stock). over 220kw at fly (175kw stock). it quite easially blow my new GTR away.
soon as u get ur's change ur front wheel bearings and exhast/dump and if u can slap on a FMIC the std tmic is good but heat soak takes a toll on ur launches..
Sold mine and got a GTR R32..it is a good upgrade but needs some money into her to make her worthy of the old GTiR..
GTiR was my first and a very good learning toy.. u'll be very happy with it.. it'll get u ready for the big toys.. im 17 and i already got my first GTR ahaha.. u learn from being scared
they r nicknamed.. mini Godzilla.
sold mine for $15000. excellent condition.. new owner did a few high launches and broke gearbox and something clutch related... foolish.
GTiRoz.net is an owners club yes. but u can log in as a guest and get valuable info on them. i guess u havent done ur research. that site is the best site on the GTiR.
do urself a favour and look up the site. u might learn something
I love them to death and will probably get one after the r32 monster of mine lands :P
Greg
Monster 32 came, made 251rwkw's on light tune, I sold it and now I've got a gti-r on the way...
Says something? I think so :)
Greg
  • 4 months later...
hey mate i got one currently for sale.
asking 12k for it as i am ready to get rid of it becuase i need the money towards my new car...
ther eis not a thing wrong with this car either.
tein coilovers exhaust is about as far as mods go apart from heavy duty clutch!!!
perfect condition...
honestly anyone let me know if thye know someone interested
thanks
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
